Old 02-07-2007, 04:31 PM
ParkerMillguy is on a distinguished road
G17 to G18
I'm running a Vertical Grinder with a Fanuc control. I need to dress my wheel every cycle. I'm dressing a sperical radius in G18 (X & Z). My dillemma is this: How do I use cutter compensation in G17 to shift over for my wheel diameter and then go to G18 to dress the radius? If I leave Comp. on I get a plane change CRC error. If I shut Comp off then the wheel shifts back over to the "un-compensated" location.
My goal is to have the dress code at the end of each cycle so I don't have to manually change my "x" value every cycle.
