Results 1 to 3 of 3
Thread: Newbie question - End Mill Selection
    Sep 2005
    I have gotten the metal machining bug and after acquiring a Mill and using it for various projects, I have some questions about roughing end mills.
    I have just started to figure out how handy they are for quick clearing of the aluminum scraps I am playing with. The roughing end mills come in 30 / 45 / 60 degree helix formation and I am wondering what the difference is.
    I live near Seattle and can buy used (sometimes slightly) endmills 2 flute, 4 flute and roughing from the Boeing Surplus Tool Crib. They run from about $2 for 1/2" and under to about $15 for a good sized 2" or better. I want to know how to get the most use out of them.
    I pretty much am working with aluminum (6061) and I do not use coolant with my mill (yet) and want to know how to figure out how much material can be removed by a roughing tool and what the importance of the helix angle is. Does it affect the cutting speed, the finish which shouldn't be important on a rough cut, right or tool life?
    Any help is appreciated,
    Thanks,
    -Manny
    Feb 2006
    If you are manily working with Alum. I would say two flute to eliminate rubbing cutting edges and to increase chip evacution. Four flute will rub causing wear and will gum/clog up easier, even more since your not using coolant.
    I did a quick search and came up with this for helix angles:
    http://www.manufacturingcenter.com/t...ing_around.asp
    But for your best results I would look up the manufacturers callout for each tool.
    HTH
    Custom/Repair CNC/Machinist
    Mastercam V9.1/X/X2 Mill Lathe Solids
    Sep 2005
    Bmackinnon, thanks that link is what I was looking for.... should get me off to a good start. I will also check the manufacturer's specs.
    -Manny
  1. newbie help bit selection
    By DrStein99 in forum DIY CNC Router Table Machines
    Last Post: 10-25-2005, 09:08 AM
  2. Bridgeport mill newbie question...
    By GalaticDan in forum Bridgeport and Hardinge Mills
    Last Post: 06-06-2005, 03:02 AM
  3. Newbie question
    By sdrc92126 in forum Benchtop Machines
    Last Post: 09-02-2004, 03:11 AM
  4. Newbie Question MasterCAM Mill for Router
    By Sanghera in forum Mastercam
    Last Post: 04-28-2004, 11:41 AM
  5. Computer and software selection question
    By Darren_T in forum DIY CNC Router Table Machines
    Last Post: 02-24-2004, 12:32 PM
Visitors found this page by searching for:
Nobody landed on this page from a search engine, yet!
SEO Blog
