Old 02-02-2007, 11:43 PM
Ashu is on a distinguished road
Question Diff case machining
Does any body know the machines for Diffcase machining?
Not for outer operations on diff case but all inner operations like Thrust face, Sperical dia boring, pinionmate boring etc.
I am looking for the machines to buy. Does Turn-mill mchines or SPM is suitable? Who are the machine tool manufacturers for this machining?
Old 02-03-2007, 03:07 AM
Genguy's Avatar
Genguy is on a distinguished road
On large engines we use a system similar to this one:
http://www.americanmachinetools.com/Line_Boring.htm
It should work for the bores that are in line with the axle. For the pinion bores you can use a conventional milling machine with a boring bar.
If you're doing higher volumes, it may be better to remove the axle housings and machine the center sections on something like a horizontal mill with a tombstone, then re-weld in a jig.
Collets: what's the diff... DSL PWR CNC Tooling 4 02-13-2007 02:14 PM
What's the diff between CNC Router and CNC Mill ? berryCR General Metal Working Machines 15 06-09-2006 09:24 AM
Oak Case jhwatts Employment Opportunity 3 11-30-2005 06:11 PM
case resources mvaughn General Electronics Discussion 5 05-11-2004 06:04 PM
