Old 02-01-2007, 06:20 PM
Gold Member
InspirationTool is on a distinguished road
Small, *vertical* metal bandsaw? cutting 12 ga 304 ss sheet...
I am doing a lot of prototypes in 12 gauge 304 stainless. Usually, in production, I'll have the parts laser or waterjet cut, but I want to be able to sketch a design at breakfast, and have it in hand by lunch. So, I'm thinking about a vertical metal bandsaw.
* How hard will it be to cut 12 gauge stainless on one of these? I'm used to a 14" delta wood bandsaw.
* I know about the 4x6 cheapie horizontal/vertical saws. They give me the willies looking at them when they are vertical. Is there another option without going to a $1000 14" vertical metal bandsaw?
* I don't cut up lots of stock, so I don't think I will miss the horizontal aspect. Is there something else I'm missing?
* Do you think I could take a 12" jet wood bandsaw and change the pullies to slow it down enough?
* Any suggestions on blade?
* Any other suggestions?
Thanks!
-Jeff
Old 02-02-2007, 08:26 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
You will not get your wood Bsaw slow enough UNLESS you do like we did on our first Vert saw, add a gearbox to get your SFM down to 150 - 250.
You will want to use a 14 TPI (or so) blade that is a high quality bi-metal construction.
You will also want some ear plugs - cutting sheet metal really sings.
www.integratedmechanical.ca
Old 02-02-2007, 08:46 AM
Gold Member
Thanks DB...
I found a used 10" rockwell that is belt driven that I should be picking up today.
I'm hoping it is belt driven from the stand so I can do a two stage pully reduction. I calculate I can get it under 200 SFPM that way.
Would it help to double stick tape the sheet to a sheet of plywood for support while cutting?
-Jeff
Old 02-02-2007, 09:12 AM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
Not to be a nuisance, but my Wilton band saw (Enco model #505-1372) has a range of 32-3000 SFM, and I've had little fun cutting thin stuff especially stainless!
The rule is to have three teeth in the work at all times, so make sure you have a really fine blade!
Eric
Old 02-02-2007, 09:15 AM
Gold Member
I'm planning on getting a 24 TPI blade for it....
If it works out, I'll do a web page article up.
-Jeff
Old 02-02-2007, 09:30 AM
DareBee's Avatar
Well - not trying to stir anything up but IMO 2 teeth is proper engagement.
You have to be careful with SS because it work hardens very easy. It is better to use a more agressive cut to help reduce the potential of this.
Flood coolant will work, paste will make the chips stick to the teeth and cause problems (potentially broken teeth).
Vertical/Horizontal Bandsaw purchase ChrisJ General Metalwork Discussion 3 07-21-2007 09:30 AM
Bit recommendation for sheet metal adda General Metal Working Machines 0 01-26-2007 02:50 PM
Horizontal metal bandsaw for home shop jl123 General Metal Working Machines 22 01-16-2007 08:05 PM
Tog Gun Construction From Sheet Metal username132 Europe Club House 0 01-15-2007 08:11 AM
Small 4 axis CNC bandsaw BALLSCREWPRO General Metal Working Machines 4 09-29-2006 02:28 PM
