Old 02-26-2004, 05:17 PM
Stevie is on a distinguished road
Nuts; I'm thinking about my nuts
Hi guys; had a wierd idea today while my lathe was running (strange how a mind can wander at work; heheh)
My crazy idea is to make the ball screw static; and make the ball nut spin inside 2 support brgs; I can drive the set-up with a timing belt; this will give a nice reduction and increase the step accuracy; I was thinking about it because I want to remove that lump (stepper motor) sticking out on the end of the table (X axis); I have already designed the Y axis stepper inside the main back support of the vertical slide (Z axis); now if the X axis stepper could be installed in the middle of the cross slide block; the machine would have a nice clean look
Any ideas on this you design guys
Old 02-26-2004, 06:00 PM
balsaman's Avatar
balsaman is on a distinguished road
That idea is also great for reducing shaft whip for high speed applications. That is why it is usually implemented.
E
I wish it wouldn't crash.
Old 02-26-2004, 06:27 PM
Yeah i guess so; i just found the thread about this very thing; so i guess strange thinking is common here
Old 02-26-2004, 06:50 PM
h3ndrix is on a distinguished road
Hey stevie,
Hey, I can gurantee that that idea WILL work. How do I know, well, the Bridgeport Interact 1 CNC we have here has the timing belt on the Nut of the ballscrew. The ballscrew shaft is stationary and its hollow. Its about 2.5" in diameter and the spindle shaft runs through it. So, the machine moves the Z-axis by turning the nut, instead of the ballscrew. How about that
Good luck,
h3ndriX
Old 02-26-2004, 06:56 PM
what a great idea; running the ball screw shaft around the spindle; "spacesaver design"
Old 02-27-2004, 03:06 AM
limbo is on a distinguished road
If your main goal is just to have the X-stepper inside the machine you can mount it "inside out", next to the screw to the end panel, and use a timing belt and pulleys. This also serves as the flex coupler. Several machines here have this setup, including mine.
John
Old 02-27-2004, 05:21 AM
Think Bridgeport style; kinda tough to hid a NEMA34 inside the table end; I was thinking more to enlarge the space under the X slide by moving the base and the Y down; as I'm still in the design stage it will be easy (till I start to weld a structure up)
Old 02-27-2004, 06:04 AM
Now I see what you mean At first I hadn't noticed that your post was in the Metalworking Machines section. Probably a tough job to free up space between X and Y and still keep everything rigid. Curious to see how you are going to approach it.
John
Old 02-27-2004, 03:45 PM
Here is a screen shot of my revision in surfcam; I've punched a hole through the cross slide and moved the stepper into the space below the cross slide; the bracket to hold the stepper is not drawn yet; nore the pulleys etc; the gray round bar is the ball screw; the red bars support the NSK rails (light blue) the green is the cross sldie; and rearmost green is the rear support of the vertical spindle head; purple is the base block; I'm sure you can figure out the steppers; I'm sure as I had to just hollow out the cross slide and move the cross slide nut/ball screw only 30mm to the right; the metal version will be easy too
The only concern now is the small clearance from the stepper to the base block; I've only got 2mm; I'll just have to make sure no chips get in there
Old 02-27-2004, 06:26 PM
Mr.Chips's Avatar
Gold Member
Mr.Chips is on a distinguished road
I really like the idea of not spinning the ball screw, solves a lot of problems such as whip.
Hager
  #11   Ban this user!
Old 02-27-2004, 07:16 PM
I just updated the image to include the moved Z axis stepper motor; I've decided to move them both; I'll mount the stepper on a removable plate set into the side frame of the back support
for the image I've deleted one surface to show the stepper in the new position
  #12   Ban this user!
Old 02-28-2004, 05:55 PM
I'm going to up-date the other thread about the mill project; I feel this one has run its course; as I found out its semi normal to rotate the nuts
please use this thread to reply http://cnczone.com/showthread.php?s=...4222#post24222
Anti - Backlash Nuts Mhiran DIY-CNC Router Table Machines 62 02-18-2010 07:55 AM
Nuts are driving me nuts! Cold Fusion CNCzone Club House 9 06-12-2004 11:40 PM
M12 x 1 nuts needed georgebarr DIY-CNC Router Table Machines 3 02-27-2004 06:22 PM
Lost my nuts! kong DIY-CNC Router Table Machines 7 08-18-2003 12:56 PM
Plastic Nuts ger21 DIY-CNC Router Table Machines 8 06-19-2003 07:49 AM
