Old 01-31-2007, 06:46 AM
Janos is on a distinguished road
Fabrication of chip auger
Hey all
I wrote in a while ago about if someone knew if there was a auger setup for the Hardinge Quest 6/42 and due to the sheer lack of response I gather that there isn't any.
So I must ask is there a way to aquire parts such as the motor/gearbox and chipscrew to fabricate one from? I don't have a problem with modifying the sump to accept the new parts, just getting the materials seems to be the challange.
Janos
Old 01-31-2007, 12:13 PM
dartplayer1 is on a distinguished road
You can try these for your geared motor
http://www.hubcityinc.com/
http://www.grainger.com/production/i...ial-supply.htm
And I am sure these folks can help with the auger.
http://www.augermfgspec.com/standard.html
Hope this helps
Tony
Old 01-31-2007, 03:41 PM
gridley51 is on a distinguished road
You could try looking for a chip conveyor from a Wickman multispindle lathe.These use an auger,are quite narrow and are self contained.Don`t know the availability of them where you are plenty in the UK.Possibly an Acme Gridley as well.The British machines use augers don`t know about American ones.
Mark.
chip auger at tm-1 home made pit202 Haas Mills 26 12-10-2007 03:25 AM
Chip auger help Janos General Metal Working Machines 0 01-29-2007 10:40 AM
Beginner's Fabrication Reference lostbaka Suggestions for the CNCzone.com site. 4 01-15-2007 05:38 PM
auger design question erase42 Mechanical Calculations/Engineering Design 10 12-03-2006 11:13 AM
small job fabrication options Reid Employment Opportunity 1 09-15-2006 02:43 PM
