Old 01-28-2007, 07:20 PM
boringmill is on a distinguished road
Anilam DRO display
I bought (2) of these at auction,for $1.00 each.Can you mix and mactch parts with them"scales cables,etc" or do you have to have a complete unit? Thanks Chris
Name:	auction find001.jpg‎
ID:	30515   Click image for larger version
Name:	auction find002.jpg‎
Old 01-28-2007, 08:05 PM
Al_The_Man's Avatar
A couple of problems is 'reverse engineering' the scale pin-out/connections and another is wether the unit can be calibrated to the particular scale resolution.
Most scales conform to the same voltage/signal type ( 2 phase quadrature).
Old 01-29-2007, 03:56 PM
balsaman's Avatar
balsaman is on a distinguished road
Did you get the scales with?
E
I wish it wouldn't crash.
Old 01-29-2007, 07:28 PM
DRO display
No scales came with it nor did any cables.Im hoping somebody has a set laying around for sale,trade etc.Thanks
chris
Old 02-04-2007, 06:55 PM
wafarmer is on a distinguished road
Look on ebay under lathes or milling machines and look for DRo's
He lists scales for that brand they come from Singapore
Cheer's
wafarmer
Old 02-16-2007, 09:08 PM
bdambacher@dsl. is on a distinguished road
Old product and discontinued. anilam wizard programable unit. very enviable item in its time !
the scale resolution is programable and you must provide TTL signals for them.
round 6 pin connector where
a-phase A
b-Phase B
c-5VDC
d-0VDC
e-Shield
f-Marker pulse.
if memory serves you have to press 8888 to acces the axis configuration.
good luck
Toolpath display raytor Mach Mill 1 11-04-2006 09:54 AM
Mac minimum display resoution? macona Mach Software (ArtSoft software) 1 10-07-2006 11:31 PM
Set the counter display hien100881 Fanuc 6 09-22-2006 12:26 AM
Display following error Rocksalt Mazak, Mitsubishi, Mazatrol 8 08-29-2006 08:57 AM
Lasers and galvos and DXF display? DennisCNC General Electronics Discussion 0 04-10-2006 11:23 PM
