Old 01-23-2007, 08:09 PM
symage is on a distinguished road
Question Fanuc Magnetic Sensor Error
I have a Fanuc 6M control with a Magnetic sensor for spindle orientation. I frequently get sequence errors because the spindle has difficulty finding orientation in order to tool change. Is there a way to tell if the problem is with the sensor, amplifier or board without paying Fanuc a gazillion dollars for the new parts? Thanks
Old 03-07-2007, 04:02 PM
Mitsui Seiki's Avatar
Mitsui Seiki is on a distinguished road
Does the sensor have a diod so you tell if it's affected?A green or a red diod. Or maybe it shows both colors.Not at the same time of course. Turn the spindle by hand and see if it lights up.If you see two colors(Red and green)the red shows first and then the green.Maybe the sensor is too far away from the cam.
9 times out of 10 it is the sensor.
Fanuc 5T ERROR 20 alduns G-Code Programing 6 02-02-2009 05:15 PM
Fanuc 6MB Error LED tsalpha Fanuc 4 01-05-2007 08:51 AM
Fanuc 6 system error 908 hidivsultan Fanuc 0 06-23-2006 08:43 AM
Error L on Fanuc series 10 wanchai101 Fanuc 4 02-28-2006 02:09 AM
Fanuc 3T -MODEL A error 5 geroda Fanuc 2 07-08-2005 08:39 AM
