Old 01-23-2007, 07:25 PM
baran3 is on a distinguished road
*** Positioning Problem ***
I am working on a Kitamura Mycenter2 circa 1983. There is a positioning problem with the Y axis when the machine is "cold". I made a test piece where i bored two holes at the end of one day. Then i bored a third hole at the beginning of the next day. The two holes i bored at then end of the one day were accuratly spaced from each other, but the one i did the following morning was .004 from its programmed location in the Y axis. (The X position was perfect). I've tried locating a surface and then running an then moving the table in a looped program for more than an hour to see if I could pick up a change, but the most i got was only .001 when i used rapid movement to warm it up. Feeding an arc produced no change in my zero. The Y axis motor on this machine is not directly connected to the ball screw, there is a shaft that connects the two. This is the only machine we have like that. Does anyone know what the problem may be?
DRO positioning is Wrong.How to fix? GisMo Machines running Mach Software 5 10-15-2006 07:20 AM
Boss 5 X axis positioning kewl_cat Bridgeport and Hardinge Mills 1 01-07-2006 10:04 AM
Fanuc O-M positioning 723 General Metal Working Machines 8 07-30-2004 08:09 PM
photomicroprocessors for positioning turmite General Electronics Discussion 0 06-24-2004 11:37 AM
Alternative positioning idea. ynneb Machine Problems, Solutions , Wireless DNC, serial port 3 02-19-2004 10:54 AM
