Old 01-18-2007, 10:32 PM
bjinatj is on a distinguished road
Lathe axis question
I recently purchased a combo mill / lathe, I have no idea how to use a lathe. I do a lot of mig and tig and thought it would be fun to learn a lathe.
The question I have is I can see the lathe has a x and y axis, but I cannot find a z axis to center my cutting tool. When I mount my cutting tool to the tool post is it just centered with shims, or is there a way to move on a z axis?
Thanks for all of your help!
-Ronnie
Old 01-18-2007, 11:04 PM
Al_The_Man's Avatar
I think you are refering to tool height, usually shimed to centre of the material/stock, the axis on a lathe is X across the face of the chuck, Z through the centre of the chuck to tail stock centre.
The tool height adjustment depends on the type of tool post.
Old 01-19-2007, 07:47 AM
That is pretty much what I assumed. Thank you for your reply, it was very helpful.
Keep up the good work all!
-Ronnie
Old 01-19-2007, 01:49 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Ronnie, a lot of folks buy a quick change toolpost (QCTP) for their lathes. These have a little screw on the tool holder to vary the tool height. Phase II and others make QCTP's for smaller lathes.
Best,
BW
Old 05-14-2007, 09:57 AM
nthrower is on a distinguished road
Wink Re centring of cutting tools
You can always put a centre into the headstock, and then use it as a basis for shimming up the cutter.
Alternatively you can always try facing off a piece of bar stock. If it leaves a pip on the end, it is too low. If runs clean across then you are OK. If it seem to stick at the centre point of cutting - it is probably too high, as the bottom of the cutter is now trying to push past the pip.
I'm a relative beginner too.
