Old 02-13-2004, 05:09 AM
h3ndrix is on a distinguished road
New Spindle Design, feedback plz!
Hi ppl,
I know I ve been asking questions and jumping from subject to subject, but I am in my research phase for the CNC that I am building. After I found out that I was not going to be able to use the small bridgeport for my project, I decided to make my own CNC, from ground up (well...almost). Here is some progress:
This is the spindle design, with automatic tool changing capability, that will fit a Mini Mill head from Harbor freight, Grizzly etc.:
It will ride on two angular contact bearing OD: 62 mm ID: 30 mm.
All parts are stell except the orange part and dark green part on the back, which might be made from silicon bronze.
-It features a NMBT 30 collet with standart 45 degree retention knob.
-It has a holding system which is very similar to a quick connect hose fittings that are on compressor hoses. The bright green are the steel balls that will fall into the groove on the spindle when the bar is compressed down.
-It has a die spring which has a rated force of 500 N. It will be under compression when the collet is in the spindle.
-The spindle nose is a standart nose (measurements taken from Machinery's Handbook) , but it is missing 4 screw holes and the two ears that I will add later.
-The system will be activated by a linear actuator.
-The hole running thru the middle is for coolant to the collet.
Please give me some feedback on the design guyz. Oh, and if someone wants to make it before I ever get to it, feel free to do so, but let me know of the progress.
Thx,
H3ndriX
Old 02-13-2004, 09:06 AM
Gold Member
Ken_Shea is on a distinguished road
Tool changer
I like it !,
Good thinking.
Thinking on the the use of the silicon bronze, would not these pieces be carrying the entire load and be subject to quick wear?
This material makes a great bushing but not much for strength.
Keep us up to date on your project.
Ken
Old 02-13-2004, 09:19 AM
Thx Ken,
This silicon bronze I am talking about is unbelievably hard, they usually use it on casting sculptures that are big in size . But, then again, you might be right, I am still researching the materials I will use on the spindle and silicon bronze, like you said, might not be a good idea.
Thx
H3ndriX
Old 02-13-2004, 11:21 AM
HuFlungDung's Avatar
Moderator
A few observations: I don't see the bearing surface for the large angular contact bearing. It should be right behind the main flange, but you are showing an angled surface there.
It is not a good idea to use only two bearings. The heat buildup needs to be compensated for, or the bearing preload will increase as the spindle warms up and bearing failure will ensue because they will run really hot.
So, use pairs of angular contact bearings, with the larger main bearings being a preloaded set that mounts back to back in the lower end of the housing. This pair is securely locked in place to position the spindle accurately (axially) in the housing.
The upper pair of bearings should be fastened securely to a shoulder on the upper end of the shaft. They are also a preloaded set that are locked back to back on the shaft. However, the outer races on this pair should be a close slide fit in the housing. This is where the expansion and contraction is compensated.
I am not sure about the die spring. Belleville washers have advantages because they might give better balance. They are also very stiff with a very high spring rate. But, one thing I have not figured out about the "real cnc's" with this retention knob system, is what is applying the pressure to release the tool, and what is bearing the load while this takes place. I'd like to see something that is not pressing the hell out of the spindle bearings and Z axis ballscrew supports. Ideally, this would be something that locks onto the spindle shaft itself, and then bears against that lock and the spring to do the tool release.
Old 02-13-2004, 12:11 PM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
Here is shot of a Famous name machine tool draw bar.
Hope it helps. You are very close to it's design.
Old 02-13-2004, 12:29 PM
ThX Hu,
Right after the angled surface on the spindle nose, there is a flange, which is for the inner race of the first bearing, the second bearing, which will be on top, does not have a flange, this is because the flange is on the casting side and the inner race will be secured by the space and nut that will fit on the spindle outside (which is not on the drawings).
The reason why the spindle was made this way was to be able to put it into a mini mill head, which can only take two bearings. Ideally 4 bearings would be the way to go, but the casting does not have any machinability on it for extra bearing surface. BTW, the reason I am using a mini mill head is because I don't have enough money to get a cast iron head cast and dont know anyone with the facilities.
I am still researching the belville washer deal, but I do not know how they opperate to allow for constant force, which is what i need.
I will post a drawing of the head when I get home, so it will be easier to understand.
Thx,
H3ndriX
Old 02-13-2004, 12:32 PM
THx Wms!
It is close to impossible to find a image like that, I gave up looking and decided to design my own, then something flashed in my mind as I was getting ready to spray paint my table with clear coat when I plugged the hose into the gun and bam!
Quick connect!
Then I realized how similar the quick connect male connector is to the retention knob design, then I went from there.
Thank you for posting that, that just makes me feel alot more better
H3ndriX
Old 02-13-2004, 12:53 PM
WOLOG's Avatar
WOLOG is on a distinguished road
There is a quick release kit that you can buy for a R-8 spindle. The R-8 collets have a built in retention knob. I think it uses a die spring also. Maybe you can get some ideas from that. I will look for the bookmark on my computer when I get home and will send it to you.
Old 02-13-2004, 01:55 PM
Wolog, thx for the heads up, I have seen what you are talking about, but it was really hard to understand anything from it, and they dont have any mechanical drawings of it. Costs around $1000 too. Thx though
Here is a pic of the assembled pieces with the mini mill head:
I hope it is clearer why I have to use 2 bearings instead of 4 and why there is no upper flange. Hu, If you have any ideas on how I could fit 4 angular bearings instead of 2, I would be glad to hear it
Thx
H3ndriX
Old 02-13-2004, 04:24 PM
Moderator
H3ndrix, those are real pretty pics
You can count on the spindle becoming hotter than the housing. The length between those bearings simply increases the total differential of expansion. Your bearing preload will be lost with the bearings put in that way.
If you turn them around, they will get too tight.
Edit: they won't get tight if they are not restrained in the housings, but instead, the bearings will move away from the shoulders in the housing. This will make the Z position slightly unstable.
Here is something to consider: instead of mounting the bearings directly into the casting, you could machine some bearing housing blocks that would fit in like extensions, either outwards, or inwards, as you might find room.
Old 02-13-2004, 05:19 PM
Moderator
I had to rush away, but I'm back. I wanted you to consider the overhang of your current design. A reasonable boring bar overhang/diameter ratio (in lathework) is between 4:1 to 6:1 max. This affects the vibration of the bar.
So, you would check your estimated tool overhang from your frontmost bearing, divided by the 30mm diameter of your spindle at that point. Already, your tool is working on the extreme limits, and vibration will be a problem.
So, if you create an extension "pillow block" that slides (with a pressfit) into your existing housing bore, then, you can use larger ID bearings on the main end, and move them further down towards the end of your spindle, where you now have that empty tapered zone.
  #12   Ban this user!
Old 02-13-2004, 05:52 PM
Stevie is on a distinguished road
What you need is called Amco Bronze; we use it for slide guides in Injection molds; very hard to machine and tap; the wear rate is very low
I'm sure it's an alloy of Alumi and Bronze
and for sure the bearing needs to be extended into the tapered zone; or simply add another
