Use a centrifigal pump, as you can dead head the pump with no ill effects. I'd go with a relay for the pump, with separate switches. To minimize the wireing requirements get a relay with a low voltage ac coil, then use a door bell transformer, and door bell wiring. If you want to get fancy use a remote controlled relay, and leave a couple remotes around the shop.
http://www.nextag.com/remote-control-relay/search-html
LinkBack URL
About LinkBacks
