Old 01-02-2007, 06:00 PM
91bird is on a distinguished road
Terminology question
“Swing” or “swing over” on a mill = distance between spindle and column?
Old 01-04-2007, 02:52 PM
kevindsingleton is on a distinguished road
Usually, it's twice the distance between the spindle centerline and the column. For instance, a 12" swing would indicate 6" between the spindle centerline and the column.
Old 01-04-2007, 10:50 PM
ViperTX is on a distinguished road
Well I've never head of 'swing' used in relationship to a Mill. Swing is always referred to as the maximum size that a lathe can 'swing' over the carriage, etc.
On a mill and every VMC that I've seen.....'swing' is never used...it's always distance from spindle centerline to column....
Old 01-05-2007, 01:43 AM
Grizzly uses the term in the description for a mill I was looking at:
http://www.grizzly.com/products/g0463
So does harborfreight:
http://www.harborfreight.com/cpi/cta...emnumber=44991
The X2 and X3 are the mills I have been looking at and maybe swing is a term used for some reason to describe these mills in this particular case?
Old 01-05-2007, 01:45 AM
Thanks for the help.
Old 01-05-2007, 02:29 AM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
I agree with Viper - swing is usually related to lathes, not mills - at least in my experience.
I think this is a classic case of "Chinglish" that has been inherited by the tight knit group of foriegn suppliers. They make lathes, they make mills - why not use the same terminology?
In this context, I would have to agree that the swing indicates twice the maximum from center of spindle to the column. I'll agree with that as the dimensions seem correct.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 01-05-2007, 12:24 PM
The term I'm familiar with for distance between spindle centerline and column on a vertical mill is "throat". On a horizontal mill it is usually described as spindle C/L to table min.-max. This can also be the case for a vertical mill with a moveable ram, min. throat, max. throat.
DZASTR
Old 01-07-2007, 12:04 PM
Thanks, that helps clear things up.
