Old 02-08-2004, 02:54 PM
kong is on a distinguished road
Lathe opinions, help identify!
Hiya guys, I'm looking for an import lathe to replace my tiny Taig thing, coz it simply isn't big enough anymore. Being in the UK, the choices are limited, but I quite like the look of this one. It's a "BV20M", I am unsure of it's origin, but if you have any experience of something similar, please let me know what you think. I'm not turning big stuff, and I'm not trying to break any speed records here, so this is an "occasional" worker. Hope you get the idea!
Old 05-14-2004, 02:54 AM
chelsea7 is on a distinguished road
Have a look at Dajoosanga Machine Tool Co. Korea. BV20M looks like DML200
Old 05-14-2004, 03:54 AM
Thanks Chelsea, I bought the lathe some time ago, and am amazed by it's quality for the small price. Axminster are doing some great stuff these days.
Old 05-27-2004, 10:58 AM
Have also now bought a BV20M and am amazed how accurate it was on delivery. Spindle run out less than 4 tenths and with test bar between centres worst point was just under a thou over the whole length. The only problem so far was that two of the holes in the cabinet were drilled in the wrong place by 10mm. Also it is not the most rigid and I have has to strenghten it up.
Old 05-27-2004, 11:33 AM
Funny that, I had to re-drill the cabinet too! A word of warning - the suds tray will leak through into the cabinet if you are using flood coolant. I have put a load of silicone in and around the base of the lathe and in the bolt holes to stop this from happening. If you are looking for some quality tooling, I got a set of glanze 12mm indexable tools from www.chronos.ltd which are excellent value for money. Enjoy the lathe!
Old 05-28-2004, 02:53 AM
Did you find the gearbox very noisy at first but quieten up after some running off load and some uce cutting metal?
Old 05-28-2004, 07:23 AM
Yeah that gearbox sounds as though it is rattling! Mine tends to sound smoother when I am cutting. That reminds me, must be due an oil-change soon?!
Old 05-31-2004, 09:10 AM
I forgot to add - many thanks for the tip regarding sealing the holes in the tray against coolant leaks.
Did your lathe come with a cutting feed chart? Mine only had the spindle speeds and thread cutting charts.
If you have one and could publish a copy I would be grateful and would save me the maths.
Regarding the gearbox, if you look in the front of the manual it says fill with SAE 20, but in the back it says EP90. After speaking to Axminster they decided that EP90 is correct.
Old 05-31-2004, 10:38 AM
No cutting feed chart I'm affraid. Thanks for the tip on the oil though One more piece of advice - don't overtighten the nuts on the compound base, I have stripped both already, but fortunately they were easily replaced with 6mm cap screws.
Old 06-01-2004, 06:01 AM
Thanks for the tip re. compound base screws. I have asked Axminster for feed chart and if I get one I will post it on the site.
Really the machine is good value for £399 inc VAT.
  #11   Ban this user!
Old 06-02-2004, 02:34 AM
Talking to Axminster and something I should have realised, since there is no separate leadscrew gearbox, the feed rates are equal to the thread pitch rates.
  #12   Ban this user!
Old 06-02-2004, 06:28 AM
You should have had a complete set of change gears with the lathe, so you can adjust the leadscrew speed for a given spindle speed. If you are missing these, let me know since I have no need for mine.
Help me buy my first Mini Lathe Highfly Mini Lathe 20 05-10-2005 02:07 AM
OneCNC XR Series Lathe CAD/CAM Released: OneCNC Product Announcements & Manufacturer News 0 03-07-2005 04:20 PM
Just got a taig lathe. anoel Mini Lathe 2 01-18-2005 04:29 AM
Buying my first lathe, Jet, Grizzly, Central, Prazi Noah General Metal Working Machines 9 09-05-2004 10:35 AM
Mastercam lathe crash course CNCnUtZ Mastercam 6 09-26-2003 01:03 AM
