Old 12-18-2006, 12:23 PM
dpriebe is on a distinguished road
240V Deckel DE20 Sinker EDM for sale
’84 Deckel “DE 20 Center” Type G45 240V 3-Ph 4-axis Sinker EDM S/N 0492-0122 for sale. Selling as-is, where-is in Paso Robles, CA, US.
We are a captive mold building toolroom and bought the machine used in 1987.
Mechanical condition:
Clean, solid, very good. Not heavily used. Only known mechanical cosmetic defects are dented can over chuck and broken Lucite cover over vacuum flow gauge. All axes, EDM generator and functions fully operational when last run.
Electronics condition:
Monitor has no vertical sweep, needs an available chip replacement. New CRT in 2000. Not currently running.
Documentation:
• Operator/Programming Manual – English
• Burning Technologies binder - English
• Electrical/Electronics binder – German
Mechanical Specifications:
• 12x8x12” (X,Y,Z) plus C-axis work envelope
• 18x13” work table includes 3 extra work holding fixtures
• 24x18x14” work tank with pressure and vacuum flushing
• Integral dielectric chiller, pump and vacuum pump
• Variable 45A EDM generator burns in XY, XZ, YZ using manual G-coding
2-axis linear, circular, taper or spherical planetary functions
Extensive variety of burn parameter settings
Integral mini-cassette ASCII program transfer
• Automatic way luber
• Ψ20mm System-3R pneumatic electrode chuck
• Berger-Lahr drives, Heidenhain glass scales with .0001” resolution
• Adjustable work lamp
• 240VAC 60Hz, 3-phase, about 6KVA
• 3300 lb main housing + 840 lb generator cabinet + pump/filter cabinet
Asking $4000 US
Price includes loading onto flatbed - you do the tie down.
Questions?
