Old 01-29-2004, 05:10 PM
inthedark's Avatar
inthedark is on a distinguished road
Cool cutter compensation while contouring
I have a newbie question regarding 3D contouring.
When I generate a path using the center of a .5 ball mill. The path is raised .25 above the material. If I was to use this I would cut air, and the depth would end up .25 shallower than what is needed. I understand that the system is generating the path .25 above the actual tip.
When I go to cut my path what is generally done to fix this offset issue?
My controller is a Fanuc 6. Do I make a G44 length compensation toward my work, and set the rapid plane an additional .25 above the material?
I'm just trying to get a firm grasp on the obvious.
Thanks in advance for your time,
Kenny
"Plan your work; Work your plan"
Old 01-29-2004, 06:06 PM
keithorr is on a distinguished road
Not all CAM programs use the center of a ball mill. Some use the tip and compensate where needed (sides) and VM is user selectable, either tip or center.
Old 01-29-2004, 06:22 PM
inthedark's Avatar
Well my CAD/CAM uses the center only. So I need to find the acceptable method to deal with this. I have in the past moved my UCS so the code comes out as I would expect. but it seems risky, on some parts.
Old 01-29-2004, 06:38 PM
Gold Member
imserv is on a distinguished road
Most people fudge the Tool length to get the correct location.
Vector Cam 3D, is user selectable for Tool radius center or tool tip.
Your best bet is to cut some test parts to be certain that you know what is going to happen. Wood, plastic, and wax make nice testing materials and don't cost you much if the part isn't what you expected.
Fred Smith - IMService
Old 01-29-2004, 06:42 PM
Mortek is on a distinguished road
Inthedark,
When you set your tool height in the control, just set it 1/2 the diameter lower to compensate for center of the ball setting. I had the fanuc 6mb on a chiron machining center. I had to enter the H set by hand in the offset table. Just make sure you have enough clearence set in the cam program to clear the tool over the work piece on retract, or you could gouge the top. Been there done that.
Old 01-29-2004, 09:21 PM
inthedark's Avatar
OK, thanks again for the tip. I will give it a try.
I have figured out how "not" to do many things thus far.
Thanks,
What is high speed machining Klox Hard and High Speed Machining 111 01-26-2011 12:21 PM
CNC Glossary CNCadmin CNCzone Club House 17 03-09-2008 03:08 PM
long cutter options Losos DIY-CNC Router Table Machines 28 06-28-2007 01:19 AM
Cutter compensation woes!! RBCMan G-Code Programing 7 02-16-2005 09:43 AM
Looking into Plasma or Laser cutter for sheet metal NeoMoses CNC Plasma and Waterjet Machines 11 01-05-2005 11:29 PM
