Old 11-25-2006, 04:54 PM
nlh nlh is offline
nlh is on a distinguished road
Matsuura MC-500V Tool Changer Problem
I have a Matsuura MC-500V mini master w/ a Yasnac 3000G control. When attempting to perform a Tool change either in a program or in MDI I get an Alarm 25 along with a 551 code in the following format. 551..25. I have checked the micro switches but they all seem to be working. I also checked the pressure switch however I found that the previous owner disconnected it which leads me to believe they were having problems with it as well. Any of you on this board experienced anything like this? This thing is starting to drive me foolish. I get one issue fixed and 2 more pop-up, at least it seems that way.
Thanks,
nlh
Old 02-21-2007, 12:09 PM
SKIP HELLAND is on a distinguished road
Hi. I Had the same problem on my Nakamura tw-10. I called the service tech and he said that the turret is not clamped and the milling knock LS is off. To remedy it, he had me press the turret index button and the feed hold button simsutaneously. It worked! Anyway, I understand you have a different machine but try it anyway. You have niothing to lose. Good luck!
Old 02-24-2007, 09:07 AM
Mitsui Seiki's Avatar
Mitsui Seiki is on a distinguished road
Check the switches for the Z axis.Especially the home position switch.
Ok, you said you checked the switches but maybe you forgot one.
Old 02-24-2007, 09:25 AM
mike10 is on a distinguished road
toolchanger
wow those codes sound familiar i worked on a 1988 matssura 760 in 2000 and i remember those codes im pretty sure i have a (how to remedy) in my note book, because it was a comon problem ill look for it next time im at my shop,
Old 03-14-2007, 01:40 AM
flytiger is on a distinguished road
I have problems with matsuura mc500v m5g(nc). We lost the nc manual. Could someone help me out? Thank you very much!
Old 03-14-2007, 01:42 AM
How can I get the NC manual please? My e-mail: flytiger_101@yahoo.com thank you!
Old 03-30-2007, 02:46 PM
kzajko is on a distinguished road
Hello, you can check information about Matsuuras here:
http://www.acmanufacturing.com/elist.htm
There are specifications included.
The last resort to get a complete manual will be to contact Matsuura directly:
www.matsuura.co.jp I recently tried to find manuals to older Matsuura machines and it is not easy.
Chris.
Cnc Machine shop
Old 03-13-2008, 01:11 PM
ptkk is on a distinguished road
Thanks,
nlh
i am facing same problem on mc500v with yasnac 3000g,can you pl suggest
kamal
Old 03-14-2008, 08:20 AM
lshingleton is on a distinguished road
First-Can you reference the machine-x,y,z
Second--Can you put the machine in manual and put a tool in the spindle
Third---Has the machine in mdi been sent to tool change position--these older machine used to use O8000 or O9000 progams to do this--------or type in,
G00G91G30Z0
G00G91G30X0Y0M19
G90
LAST---When you precall the tool like t1 does the magazine move----does it reconise t1 positon------some things to check and hope it helps
Old 03-14-2008, 08:42 AM
thanks a lot for your reply.
first i would like to inform you that we have just purchased this mcn and this problem started coming after we have replaced both the batteries and we have re entered the parameters, presently there is no programme of offsets stored in the memory.
-Can you reference the machine-x,y,z-------yes i can
-Can you put the machine in manual and put a tool in the spindle------yes i can.
-Has the machine in mdi been sent to tool change position--these older machine used to use O8000 or O9000 progams to do this-------when we do Z home ,ATC ready/ home led goes on. how to find out tool change position.
-i have tried-
this program in MDI after moving all axis away from home positions
G0G17G40G49G80G90
G91G30Y0Z0M19
T1
M6
-it seems this can be done block wise only?
-when i do the first block nothing happens but when i do the 2nd block alarm 14 comes.?
i also tried
G0G17G40G49G80G90
G91G28Y0Z0M19
T1
M6
-by doing this block wise
when i do first block nothing hapens and when i do 2nd block y and z go zero position but there is no tool change.
-or type in,
G00G91G30Z0
G00G91G30X0Y0M19
G90
- i will igve you feed back by doing this tommorow.
LAST---When you precall the tool like t1 does the magazine move--- no
-does it reconise t1 positon--- when by manual indexing we bring tool position 1 in front of spindle and then we give m6 and t1 command alarm 25 does not come.?
---some things to check and hope it helps----------kindly devote some time we will be greatful
reagrds
kamal
  #11   Ban this user!
Old 03-14-2008, 02:19 PM
Hi
The G00G91G30Z0.-first takes the z safely away from the table
The G00G91G30X0----X-is the most important one and the center of the table should be directly under the spindle and y should remain at home--these machines used to have half guards around the table with a cutout at the back-if x was not in the right position -indexing the tools ripped the guards off--so its important on the machine to be at that 2nd reference to do the tool change
Did you find the Manual for this machine yet?
  #12   Ban this user!
Old 03-15-2008, 02:05 AM
matsuura tool change alarm 25 comes
thanks,
G00G91G30Z0.-when we tried this ,z does not go to home and alarm comes.
G00G91G30X0---when we tried this ,x does not go to home and alarm comes.
but when we did G91G28 X0Y0Z0M19----- x y and z go to home.but still when we try tool change with m6 alarm 25 comes.?
Did you find the Manual for this machine yet?-- yes i have the operator manual.
pl suggest.
kamal
