Old 11-03-2006, 06:54 PM
Tristar500's Avatar
Tristar500 is on a distinguished road
CNC metal C frame build
After posting a query regarding the possibility of building a mill from structural steel tubing and then filling the tubes with concrete I've taken the plunge.
Here the parts are mocked up in my shop with clamps to give me an idea of how the finished machine might look.
Old 11-03-2006, 07:00 PM
Tristar500's Avatar
I got everything lined up and welded in place and readied the kiln to stress relieve the frame before grinding/fly cutting the mating surfaces true.
My wife built a pottery kiln some years back and I was in luck it fit in no problem.
Next I brought the base and upright to temperature or 1150 degrees for 5 hours.
When done, I shut off the gas and waited for it to cool.
It's done when a toothpick comes out clean right?
Old 11-03-2006, 07:11 PM
Tristar500's Avatar
Talking
Here's a CAD file of the design.
Old 11-04-2006, 12:46 AM
paulC is on a distinguished road
Nice work. I'm a bit ignorant on the use of concrete in steel. Is reducing the strees a requirement for the concrete or for the grinding?
Paul
Old 11-04-2006, 07:54 PM
saris is on a distinguished road
Paulc: no expert, but i think you want to stress relieve the steel (or alot of materials) before you final machine the components true to get all of the movement out of the material. IF not stress relieved, if you machine something thinking ur gonna get acccurate parts, the material will move, or spring in some unknown direction, and ur parts won't be what u think ur getting.
1 So stress relieve
2 Machining
3 Sometimes for BIG parts, another round of stress relief
4 Final maching
5 inspection
Old 11-04-2006, 08:17 PM
When you do your machining I suggest you take everything down to within 0.020" of the final dimensions and check to see if things have distorted. You have welded together very different thicknesses and your first stress relieving may not have released all the stresses between these sections.
Old 11-05-2006, 06:53 PM
Tristar500's Avatar
It looks as if I will have to have the mating surfaces to the bearing rails ground but will have to have the end of the base fly cut as it won't fit on any grinder in town. This shouldn't be a problem as it would be easy to shim if necessary the uprights to the base.
L
Old 11-13-2006, 03:20 AM
Bill Johns is on a distinguished road
Good idea.
Where is a good source for the ball screws etc.
Why not just use thicker cross section steel instead of the concrete?
Is there any info on here about using concrete?
Old 11-15-2006, 08:28 PM
Tristar500's Avatar
The mill is reall coming along now. It's back from the ginding shop and I've had several days to work on it.
Old 11-15-2006, 08:32 PM
Tristar500's Avatar
OK, gang, I'm really getting into it. Here's a shot of the z axis stand-off blocks coming together. Notice the sweet finish the facemill leaves on the aluminum!
Nice!
  #11   Ban this user!
Old 11-15-2006, 08:34 PM
Tristar500's Avatar
tolerances are looking really good, so far .00005 or better.
  #12   Ban this user!
Old 11-16-2006, 07:35 AM
Tristar500's Avatar
Originally Posted by Bill Johns View Post
Good idea.
The concrete will dampen the natural resonance of the steel tubing.
When unfilled the tubes ring like bells.
