Old 01-15-2004, 02:45 AM
daddyhobby is on a distinguished road
Recommendation for stepper motor and driver
I planned to design and build my own CNC milling from scratch. It will only be doing stuff on AL6061. I would want a travel of say X-300mm, Y-200mm and Z-150mm
Can anyone give a recommendation of which stepper motor and driver can do the job. Thanks in advance.
Mike
Old 01-15-2004, 05:07 PM
Swede's Avatar
Swede is on a distinguished road
Mike, are you set on using stepper motors? Servos will be nicer, especially if you are going to work hard on building a nice, rigid, and accurate metal-cutting machine.
That said, a lot of the guys here swear by the Gecko systems, although I personally am using Flashcut because I like their software very much.
What will the mill look like? Traditional moving table, gantry?
Swede
Old 01-15-2004, 06:13 PM
IndHobby is on a distinguished road
Stepper Motor and Driver
A NEMA 34 640 in/oz Steppers and a Gecko 201 's / heat sink will easily convert a bench mill to CNC, so it will cover your application.
You just need to make sure the voltage stays below 80V @ 7 amps.
Aaron Moss
www.IndustrialHobbies.com
Old 01-15-2004, 06:40 PM
pack rat is on a distinguished road
I think the man is seeking an advice and not a price, .
Old 01-16-2004, 05:39 PM
Thanks for the reply so far. Yes I am going to make my own CNC mill. Design will be base on some Mitutoyo Quick Vision system, with Y axis as table moving , X-Axis a bridge/Gantry across w Z-zxis mount on it.
I would like to start off w stepper setup cos it probably be less complicated and cheaper I am totally new to this CNC tho I had a passion for it. So keep yr suggestion coming and thanks in advance!
Cheers
Mike
