Old 01-03-2004, 04:23 PM
ijzerman is on a distinguished road
need help with cnc problem!
Hello,
I need some help with my cnc mill !
Please check this site: http://members.lycos.nl/jcijzerman
Old 01-03-2004, 04:28 PM
balsaman's Avatar
balsaman is on a distinguished road
It looks like you are loosing steps. Set the speed in the software slower and try again.
Eric
I wish it wouldn't crash.
Old 01-03-2004, 05:09 PM
balsaman's Avatar
Also, a lot of laptops put out ~3 volts at the parallel port instead of 5. Cnc control doesn't really like this. Try it on a desktop computer and see if it's better.
Eric
Old 01-09-2004, 01:28 PM
inthedark's Avatar
inthedark is on a distinguished road
When I retrofitted my bridgeport, I was geeting very much the same issues. I was lucky to have a manual, and verified all the voltages and amperage from the main powersupply to the circuit feeds on to the stepper motors. It did take some time, but my stepper motors were high on voltage and low on amps (if remember correctly). But once I got everything adjusted correctly, the problems went away. I found that a faulty fuse holder could reek havoc as well.
Good Luck
"Plan your work; Work your plan"
Old 01-09-2004, 04:25 PM
anoel's Avatar
anoel is on a distinguished road
Either loosing steps or the Pen is shifting in it's holder or something like that... Or possibly the gantry is not tight and is shifting.
Nathan
Old 01-10-2004, 10:00 AM
inthedark's Avatar
can someone define Gantry?
Using your CNC Mill as a CNC Lathe lstool Knee Vertical Mills 10 08-02-2010 12:06 AM
Problem machining accurate size part on my Bridgeport CNC conversion fastturbovet General Metal Working Machines 5 05-24-2005 12:01 AM
CNC gantry Machine shows problem Alex S.A Machine Problems, Solutions , Wireless DNC, serial port 15 04-25-2005 03:02 PM
CNC deviation error Alex S.A General Electronics Discussion 6 10-22-2004 02:10 PM
The start of a big CNC project... UKRobotics General Metal Working Machines 10 09-30-2004 05:34 PM
