Old 12-29-2003, 10:30 PM
Schulze is on a distinguished road
Tool selection help
I am still in tech school for CNC, all I have to go is CAD/CAM and lathe programming.
I am working on a personal project that requires a G2 on the XZ axis for a mating surface. The radius is about .6275 and another on the line of a 4.0 radius.
I am confused on the proper Ball end mill I need to select. I have never worked with a ball end before and am not sure if there are any rules of thumb for selecting them.
The application is for mild hardened 4140 steel about 25 RC. I am planning on a 1/2 4 FL EM Carbide.
Quick and dirty drawing here
What I am worried about is the back end of the radius on the EM draging and giving a bad finish.
Any help with this?
Old 12-29-2003, 11:14 PM
HuFlungDung's Avatar
Moderator
Was that drawing too big for this forum? I need to get an idea of the shape you are working within. A simple surface model would be adequate
But generally, your question would be answered by this: ball mill toolpaths are calculated from the center of the ball radius, not from any point on the circumference. This is contrary to using a flat ended mill, where the Z datum of the cutter is on the bottom plane.
Old 12-29-2003, 11:35 PM
the picture is very small. but I dont know why it is not showing up.
http://www.villagephotos.com/viewpub...sp?id_=7375069
there is the address for it in my album
In a vise the bottom of the part is the side being cut. I basically just need to dish out the radius for the mating surface to another part.
I understand about calculating from the center of the nose and working off that.
Thanks for the help.
HELP Tool changer problems ddprecision Haas Mills 9 01-14-2011 04:24 PM
mazak v5/fanuc 6mb tool changer mastercam post edit wild01 Post Processor Files 1 10-26-2006 08:44 AM
Tool length sensing! Swede FlashCut CNC 15 10-12-2005 07:51 PM
Miniature Automatic Tool Changer 1ctoolfool Product Announcements & Manufacturer News 1 04-18-2005 05:56 AM
Tool Changer Problems Snel Haas Mills 5 08-11-2004 08:56 AM
