Old 09-07-2006, 01:09 PM
dholt is on a distinguished road
Exclamation Threading on turning center
Anybody have extensive knowledge on single point threading on turning center? I have some questions about acceleration and deceleration factor effecting thread pitch and thread minor.????
Old 09-07-2006, 01:54 PM
M-man is on a distinguished road
Check your manual, there you should find the factors and formula for calculating the distance to achive the right pitch.
Old 09-08-2006, 12:17 AM
CNCRim's Avatar
What is control you have? If it is Fanuc, I think all G32(or G34) are standard but you can also use G92 as well for single point. The calculation for the pitch is thead per inche(1/number of thread), and whatever the RPM you put in will be Okay the control will take care the rest just don't too high(not recommend).
T0101
G96S500M3
G0X.5Z.1
G92X.48Z-.5E.0312(Z is the depth, E is the pitch)
X.47
X.46
X.45S230(reduce RPM from 500 to 230)
G0Z.3(cancel G92)
Old 09-08-2006, 03:24 PM
T0101
G96S500M3
G0X.5Z.1
X.47
X.46
G0Z.3(cancel G92)
WHat is high rmp while threading?4000-5000 RMP ? I make alot of threads with speeds around 3000 rmp and that is alomost the speed limit on the machine.
Old 09-08-2006, 04:52 PM
Bear is on a distinguished road
WOW!
Ive been doing it wrong all this time.
Doesent matter what kind of machine or controller,
Ill give this a try!
Bear
ps anyone need a brokedown machine ?
Old 10-12-2006, 10:32 PM
Garage Shop is on a distinguished road
Threading at 5000 rpm??? DAMN. My machine would alarm because I dont think it even rapids fast enough to cut that thread.
I usually stay around the 60-500 max.
Old 10-13-2006, 12:42 AM
timlkallam is on a distinguished road
This will help it has a chart that tell you where to start depending on the rpm.
http://ctemag.com/pdf/0210-laydown.pdf
Tim
Old 10-13-2006, 10:08 AM
524 rmp cutting 3" pipethread in stainless .
4338 rmp cutting 3/8 UNC in same material..(uses 3500rmp max speed)
Of course you have to use a correct start point so the z axis will have time to accelerate to the right feed.
Old 10-13-2006, 04:37 PM
NC Cams is on a distinguished road
Am I wrong in assuming that the optimum RPM when you start to feed in the tool to cut will ultimately depned on:
A. the diameter of the part being cut
and
B. the optimum surface footage that the material wants to be cut at??
When/if you run out of rpm potential for the spindle, at that point the surface finish will start to suffer.
Old 10-13-2006, 06:17 PM
BMackinnon is on a distinguished road
and
not necesarly true when threading ... it is faster to run threads at high speeds with a good amount for a depth of cut or number of cuts compared to what the stanards/formuals call out. The SFM dosent matter as much as it would if you were turing/boring the OD/ID since you are not worrying about chip break or burning the tool/material cause you are not taking off that much at a time. You'll break/chip the insert before you burn it up if your depths are not right.
  #11   Ban this user!
Old 10-20-2006, 02:58 PM
lathe guy is on a distinguished road
I like the G76 threading cycle. Never have a problem with this.
  #12   Ban this user!
Old 10-20-2006, 03:05 PM
G76 X0.96 Z-3.5 K470(thread hight) I( for taper) D100(depth of first cut) F0.062 A60. Important, you must use G97 for spindle speed.
