Old 09-06-2006, 12:48 PM
Wallhanger4 is on a distinguished road
What Tool Can Mill this?
I have an old bathtub where the plumbing stands (comes up from the floor) on the outside. The valve seat is shot and using a blunt bar inserted into a hand drill with a piece of sandpaper glued to the tip does not correctly recondition the 'SEAT'. A seat should look something like the mound created by an insect like an ant and allow for the rubber of the valve to lap and seal the opening. Parts are not available. The manufacturer went out of business in the 1920's.
My question: What tool can I put in my drill to accomplish this. Removing the part from the system is limited to no more than a few hours (i.e. turning off the water) so sending the 'T' to a machine shop is not a cost effective solution .
Please send me mail to 'd d _ y w _ 2 0 0 6 @ y a h o o . c o m' as I don't know if the election I have made will alert me to posts of my own thread.
David
Old 09-06-2006, 01:03 PM
Karl_T's Avatar
Karl_T is on a distinguished road
A suggestion. Build an arbor to holda grinding stone. The arbor will have to be held staright and true by a fixture of some sort that attachs or clamps to the plumbing. You can't let it jump around.
Put the completed arbor with stone in a drill press or what ever you have and true it to the size (with a diamond tip trueing tool) and taper you need to grind that seat just perfect.
it will only take minutes to grind that seat like new. making up the tooling might be days.
Karl
Old 09-06-2006, 06:52 PM
cdlenterprises is on a distinguished road
Another option would be to use some lapping compound. Usually there is a male and a female part to be mated in a seat. If you have the male part, you can apply the lapping compund to it and spin it in the female part using a drill. I've seen people do this to seat valves into a cylinder head. Good Luck!
