Old 09-02-2006, 03:12 PM
northman is on a distinguished road
CNC machine for making bullets
Does anybody of you know of any CNC machines I could buy/make for making rifle bullets?
This would be for hobby use, and perhaps sell as well..
Old 09-02-2006, 05:14 PM
JPMach's Avatar
JPMach is on a distinguished road
That depends.
If you are talking about solid copper bullets like the triple shocks then any barfeed lathe would be adequte. These kind of bullets have to have the grooves in them, not for lube but for a place for the material to flow into when displaced by the rifleing.
If you are talking jacketed bullets then a barfeed lathe would work for making the lead slugs to proper size (although sever overkill). Most jacketed bullets are swaged with the jackets being fluxed and then melting the lead into them, thus bonding, and then forming up the point.
My dad casts his own bullets for his 45-70 rifle, so I have seen some of the considerations that go into them. Course he is running gaschecked paper-patched bullets with soft points. I offered to make a mold to make some ballistic tips for them but he thought that was overkill. I did make the adjustable mold that he does use, and they are not that hard to make.
JP
Old 09-02-2006, 05:16 PM
JPMach's Avatar
As far as selling them you will want to check with the BATF.
I know that loaded ammo needs some special permits if you make so many a year or something. You can make all you want for yourself but when you start selling them there may be a tax on them that you will have to keep track of.
Course your in Norway so that may be different there.
JP
Old 09-05-2006, 08:11 PM
turmite is on a distinguished road
Originally Posted by JPMach View Post
That depends.
JP
Sorry to disagree, but rifle bullets are made using hollow jackets like you said, but the led is swaged into the jacket from a plug cut from lead wire that is made for the job. There are many custom bullet making dies but I don't know aof anyone turing bullets other than the solid coppers.
Mike
No greater love can a man have than this, that he give his life for a friend.
Old 09-06-2006, 05:23 PM
nervis1 is on a distinguished road
Berger makes solid turned copper bullets. All CNC lathe bar work.
Old 09-08-2006, 09:28 PM
Ball Screwer is on a distinguished road
In any kind of volume, bullets should be made on a header. Necessary grooves and any sizing can be done on a thread roller. Turning something like that is a waste of valuable machine time.
Old 09-08-2006, 10:26 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
d2 heat treated
Old 09-09-2006, 01:42 AM
TZ250 is on a distinguished road
d2 heat treated
Code:
Serious benchrest target shooters use solid, lathe turned bullets. The bullets must be ordered in incrementally larger sizes until the barrel is worn out. Lathe turned bullets are the most concentric projectiles available. Lead core and copper jackets will never be as good, but they are good enough for 99.5% of shooters.
Old 09-09-2006, 07:01 PM
Yep the .50 cal 1000 yd record group was made with lathe turned solids. It's not a waste of machine time if each takes 20 seconds to make and you sell them for a buck fifty or two bucks a piece.
Old 09-09-2006, 07:47 PM
dertsap's Avatar
Gold Member
called easy money
if you break it the right market , a lil swiss style lathe with live tooling , 2 buck every 1-2 minutes
your right waste of time
  #11   Ban this user!
Old 09-10-2006, 01:23 PM
Clueless's Avatar
Clueless is on a distinguished road
Originally Posted by dertsap View Post
called easy money
and that would come out to be 60 bucks an hour? sounds good to me...
"Chuck Norris once walked down the street with an erection. There were no survivors." -Unknown
  #12   Ban this user!
Old 09-10-2006, 08:21 PM
DDM DDM is offline
DDM is on a distinguished road
I'm been the primary guy running and programming our Star swiss lathe at work. If you could get the material cold rolled or ground to size, I bet with the right program you could be getting a less than a 30 second cycle time. there are so many variables doing such a thing but with the right tooling you could flat crank them out. The only other faster way would probably be with a screw machine that does several bars at once.
About 4 hours south of me is Blunt or ATK or whatever they're called now and they do Speer bullets and I think CCI, I'll have to check some ammo, but most all of there stuff is cold formed in high volume from what I've heard. From my little bit of shooting most of there stuff is top notch. Manufacturing this way would lead to very high output levels in the size of operation they are running just in the one location.
Carl
