Old 07-11-2006, 03:04 PM
GNS GNS is offline
GNS is on a distinguished road
Question Excessive Power Consumption?!
Sorry, probably not the right forum but I would really appreciate any input on the following:
I've got a 3-phase 30ish CFM Hydrovane compressor rated at 5.5kw, when it's switched on I noticed the electricity meter going around at about 1kw/h per minute - that’s with nothing else other than the lights on
I've had the electric meter checked and its fine (even double checked it myself). The compressor is costing more to run than the milling machine (Haas VF5) it supplies air for.
Surely 60kw/h is impossible for a 5.5kw motor to absorb? Or am I missing something?
At 8p per KW/H it works out at £1k per month (ten hours per day / five days a week) which is ridiculous for a relatively small compressor
I know the obvious solution is to change to another compressor but this one isn't that old so would prefer not to.
Any suggestions please?
Old 07-12-2006, 12:15 PM
NC Cams is on a distinguished road
See how much power the motor pulls without the belt load of the compressor.
You may have a problems with the "starter circuit" not switching to run ciruit once the motor comes up to speed. Or a bad bearing or bad field or armature winding. Unhooked motor current draw should NOT be THAT bad.
I'm pretty sure some motors start in Delta and then switch to Wye. Pretty sure that the resistance in Delta is twice that of Wye on 3 phase.
Check to see how well balanced your phases are. Too much of a resistive or capacitive load on the line could screw up your power factor.
Check your incoming voltage - if the voltage is low, the current will go high, especially if the motor stalls a lot prior to getting up to speed.
Fianlly, check the compressor for funky check valves or hurt bearings or semi-siezed piston. High friction will load the daylight out of the motor.
You're either using power or wasting it. Trick is to find out which and why, probably by a process of elimination....
Old 07-12-2006, 12:35 PM
Al_The_Man's Avatar
I would put a clamp on ampmeter across each of the phases in turn and check to see if it is close to the name plate FLA - full load amps. The motor must be around 7~8 HP which would be approx 20amps on 240.
The internal starting switch only applies to single phase motors, It is possible you have star/delta starter. but if it stayed in star the current is only 58% of delta, you need 3 contactors for S/D starting.
And the fact is if the current was consitently higher than FLA in normal run, then this would indicate a problem and you would end up with a burned out motor.
Old 07-29-2006, 01:45 PM
GNS GNS is offline
Thanks for the suggestions, will have a look and see what I find
