pminmo,
I have purchased bronze bearings for about $1 each from McMaster Carr. Search for "plain bearings". Unfortunately the tolerance is something like +-.001". Otherwise bore your own out of oil impregnated bronze.
Chris
I have a small metal lathe, the X and y axsis of the machine I building is hardened drill rod .750 +/- .0005. I'd like to machine bearings to take advantage of the precision of the drill rod. I know bronze if used for bearings, and have seen Delrin used here. I assume the Delrin isn't hard enough to hold tight tolerences? Recommendations?
pminmo,
Chris
You could also go the linear bearing route. Look at Enco.
Search for "linear bearings" and "ball bushing". Pages 1027 - 1030.
"Bronze SAE 841", page 698.
Chris
