Old 05-29-2006, 01:41 PM
xcphil is on a distinguished road
In need of guidance
I've got an Axminster Mill which has been converted to CNC (3 axis) using a 4 axis xylotex board.
I use Pro/Engineer for work and have created cutting paths in Pro/NC and have used Vericut to check them in the past, but I want to start making a few bits and peices at home.
When I bought the machine I had it demostrated to me using TurboCNC which I wouldnt mind using.
What I wanted to know is a step by step guide to getting my 3D models to a cut peice.
If I create the 3D part in Pro/E, create the cutting path in Pro/NC and verify it in Vericut then export the g code, what do I need to do after that?
Any help is greatly received.
