Old 11-12-2003, 09:44 AM
NeoMiller is on a distinguished road
Cutting tool shape for PCB milling
What is the ideal tool shape for milling PCBs. The copper is about 20 microns thick but you cant expect the PCB to be mounted 100% flat. So I guess a cut depth of about 1/50inch would be OK. The milled path can vary be 0.01 to 0.03inch thick. Due to the thin copper layer, using a flat end mill causes a lot of edge unevenness.
Old 11-12-2003, 11:50 AM
anoel's Avatar
anoel is on a distinguished road
Check out http://www.thinktink.com
Think and Tinker sell bits specifically designed for PCB milling.
Nathan
Old 11-13-2003, 11:09 AM
thinkntink is on a distinguished road
Mechanical ething bit design
Neomiller,
There is no "best" design for an all purpose pcb etching bit. The tool shape depends on the application, the resolution that you are trying to achieve, and how much you want to spend on a bit.
The cheapest hi-resolution bits around are "V" groove engraving cutters. They offer a good combination of tiny tip geometry (typ. 0.125mm), high strength, and reasonable life (50 to 100 meters in 37micron copperclad). Their disadvantage is that they require that either the board be held VERY flat or that you use an engraving machine equipped with some kind of surface following appliance (see LPKF, T-TECH, EverPrecision, MITS, Think & Tinker).
Traditional end-mills that have been tuned for milling copperclad remove the necessity of surface following but at MUCH higher cost (go to: http://www.precisecut.com and look at the PreciseBit non-ferrous end-mills), shorter life, and lower milling speeds.
As far as degree of penetration, you generally want to impact the substrate as little as possible. Just cut deep enough to remove the copper and the underlying adhesive layer (50 microns in 1 ounce copperclad and 33 microns in 1/2 ounce copperclad)
Ron Reed
Think & Tinker / PreciseBits
What is high speed machining Klox Hard and High Speed Machining 111 01-26-2011 12:21 PM
Tool length sensing! Swede FlashCut CNC 15 10-12-2005 07:51 PM
Quick change tool system (milling) mark c General Metal Working Machines 3 02-17-2005 06:50 AM
Tool Changer Problems Snel Haas Mills 5 08-11-2004 08:56 AM
Best tool for cutting metal? PsyKotyk General Metalwork Discussion 4 04-01-2004 02:10 AM
