Page 1 of 2 12 LastLast
Results 1 to 12 of 18
Thread: Chatter while cutting...
    Registered saturnnights's Avatar
    Feb 2006
    I think I already know the answer to this (mill's too small), but I'm gonna ask and verify...
    I have an X2 mill that works well when I'm doing small cuts with small endmills, but whenever I try to work with a ball endmill larger than around 0.25", the cutter starts to chatter violently. Plunging is hard enough, but if I then start to feed in X or Y, the endmill jumps around and the whole machine shakes and makes a horrible amount of noise. I'd really like to use even larger endmills, but that's completely out of the question.
    This is why I've been thinking about upgrading to a larger mill like the RF25 clones or the small knee mills.
    Is the size of my mill likely the problem here?
    Thanks,
    Mark
    Moderator HuFlungDung's Avatar
    Mar 2003
    How does the tool look when you stop it, is it plugged up (gummed up) with aluminum? Ball mills cannot successfully plunge very far, you would have to ramp into the cut and should never go deeper than the radius of the ball. Even that is pushing things if the cut is full width of the ball, most likely the tool will plug solid.
    Try a bit of WD40 on the surface next time. This will usually prevent the tool from plugging up, but a Trico microdrop lube unit works wonders for milling aluminum and clearing the chips from the cut zone on a continuous basis. Trouble is, the Trico thingy might cost as much as the X2 mill
    Gold Member dertsap's Avatar
    Oct 2005
    canada
    i agree about the ramping it in , the cutter isn t meant to be plunged so your cutter is probably starting bad and it just carries through the whole cut
    Aug 2004
    saturnnights.....I would agree with your last assessment.....larger machine.....Hu & dertsap have great information.....but lacking that information a larger machine helps us overcome that lack of infor.....
    Apr 2006
    whats the highest rpm your machine can go?
    Registered rhino's Avatar
    Oct 2005
    wd40 will work but i have found if you use kerosene on the tool it works alot better. (that is if its building up on the cutter)
    On the other hand, You have different fingers.
    Apr 2006
    I use ballnose cutters a fair bit for engraving, I have also been known to use a small ballnose cutter to cut right through 5mm aluminum and then proceed to cut out lettering. I use a $250 AUD
    coolant tank and pump setup and flood the job with a good water soluable coolant with no problems. (keep those chips out the way mate.)
    Feb 2006
    Quote Originally Posted by HuFlungDung
    The cutter never clogs - but I'm cutting brass, so maybe that's the difference? I have tried taking small passes as well without much success. In the past, I've tried coming in from the side and taking very small cuts but it seems that the larger cutters just grab the brass and start to chatter back and forth - I can actually see the cutter moving laterally rather than just remaining still. I've come to assume (right or wrong) that the X2 isn't heavy enough to keep larger cutters from moving and that I probably need a bigger mill :frown:
    Mark
    Feb 2006
    Quote Originally Posted by brownandsharp
    It can do 2500rpm... When the chatter starts at higher speeds, it's downright frightening!
    Feb 2006
    Quote Originally Posted by dertsap
    Unfortunately, this is a manual mill so ramping is not very easy (at least, for me)
    Registered CrazyRonny's Avatar
    Mar 2004
    Quebec, Canada
    Do you feed always in the opposition to the cutting force? For manual mill it's the only way to go because manual machine have to much backlash in it. And it's more important with brass and copper, this material pull the cutter in the piece really hard. If you feed the same way of the cutting force, each time a tooth of the cutter is engage in the material, the tool is pull in from the backlash amount.
    CrazyRonny
    Mar 2005
    U.S.
    Crazy Ronnie just said what I was about to say. Make sure you are conventional cutting. When climb cutting, the cutter will try to "walk" up the piece because their is backlash. When this happens chatter is terrible.
  • Page 1 of 2 12 LastLast
