Old 03-26-2003, 03:33 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
I need lube!
What is a good water base lube I can use for milling metal?
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 03-26-2003, 07:31 PM
dcrace is on a distinguished road
coolant
I use Castrol "clearedge" semi-synthetic water soluble. Lasts in sump without going rancid, works great on all metals without staining, also when kept at the correct concentration (check with refractometer) doesn't get everything "gummy" like some others.
Although a bit pricey for 5 gal., $110.00, it will make almost 90 gal. of coolant. Good luck.
Old 03-28-2003, 05:00 PM
CNCadmin's Avatar
Site Owner
Anything else I can use, I want to keep the smell down.
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 03-28-2003, 05:21 PM
HuFlungDung's Avatar
Moderator
There are lots of different semi-synthetic water soluble coolants out there. I don't know as any of them are all that stinky when fresh.
I use Doall's Kool All 940 and have been fairly pleased with it. It doesn't smell too strong, even in mist.
Machine oils and oily cutting fluids mix with the coolant and, after a while, anything, and I mean anything will grow a bacterial slime skin. So, disinfecting of the coolant sump or tank is essential every time you change coolant. If you are lucky, you might be able to use a coolant for a month before it gets stinky, providing you have some kind of a skimmer operating to remove most of the oil from the surface.
Old 03-28-2003, 11:21 PM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
I too use Castrol Clearedge 6519 with very good luck. Sump life lasts between 4 and 6 months.
I've tried about everything and always come back to this.
It's not cheap but nothing good is. By the way I buy 6 drums at a whack, puts a real dent in the beer money. (about $800.00 a drum.)
None of the semi-synthetic mixes last forever, especially if you cut disimular metals.
If you want something to last forever try Castol Syntilo 9954.
I have one sump with 9954 in it and it has been in there for over 4 years, and still going strong.
All I've ever done to it is recharge it with a diluted mix to top off the tank.
The only pitfall to Syntilo 9954 is that it "pulls" all the plasticizers out of any acrylic parts (ie: sight glasses or windows) you might have and they will spider crack.
Two things I've found that will extend the life of any coolant are:
1) Never add straight water to the tank. (always use a diluted mix of water and coolant to top off the tank)
2) A $5.00 fish tank air pump in the tank will stop 90% of the bacteria growth and this is the smell we all hate on Monday morning (that is you guys who get weekends off).
There's my 2 cents (and worth ever penny, NOT)
Old 04-01-2003, 11:26 AM
CNCadmin's Avatar
Site Owner
Would'nt a black light kill bacteria growth too?
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 04-14-2003, 06:27 PM
Zephrant is on a distinguished road
A typical "Black Light" is not strong enough to kill anything. A UV sterilizer from an aquarium place would be strong enough to kill anything passing though it, but many times they are made of acrylic or other plastics.
Mounting a UV light over the sump is a possibility, but many things are broken down by UV, so you might destroy the coolant.
Zeph
Old 04-30-2003, 10:07 AM
GOMEZ107 is on a distinguished road
The place were I work use Cimstar Qual Star LF from Milacron,also we use de-ionized water to mix it.
The name of the "water people" is Ionics try to contact them at1-800-992-8371.Hope its helpps.
Gomez107.
Old 05-31-2003, 05:37 AM
Marty is on a distinguished road
I worked for a small company, we cut 1/16" brass and sterling silver plate. We used 1 part simple green to 2 parts water. Seemed to work just fine, although i if i remember correctly it would stain the brass a little if not washed off within an hour or two.
Old 05-31-2003, 08:34 AM
smabhyan is on a distinguished road
Try Blasocut 2000 from Blaser SwissLube.
Worth for Money Paid.
However it is not cheap.
smabhyan
smabhyan
Old 05-31-2003, 09:42 AM
Klox's Avatar
Gold Member
Klox is on a distinguished road
Southern Supplies SS27, good quality, bio degradeble, inhibits bacteria growth & DOES NOT SMELL!
Klox
*** KloX ***
I'm lazy, I'm only "sparking" when the EDM is running....
  #12   Ban this user!
Old 06-01-2003, 09:25 AM
EvilScooby is on a distinguished road
I'll second the Blasocut. We use it on everything from
aluminum to stainless steel, with the proper concentration of course.
Lube for power feed??? Steve1651 Bridgeport and Hardinge Mills 0 04-18-2005 10:34 AM
Lube for acme screw? carlnpa DIY-CNC Router Table Machines 2 02-12-2005 09:04 PM
My first lathe! What lube to use? gdl357 Mini Lathe 2 08-19-2004 12:06 AM
Trico lube in the UK? kong General Metal Working Machines 7 08-02-2004 01:43 PM
Shaft lube Zephrant General Metal Working Machines 5 06-13-2003 12:03 AM
