Old 10-28-2003, 09:24 PM
daw daw is offline
daw is on a distinguished road
plunge roughing pockets
I have heard a lot of good things concerning plunge roughing in general and am interested in trying it on blind pockets. Has anyone had experience with such machining? I am most curious about cutter size and chip evacuation. I often rough pockets that are approx 12 by 18 by 3 to 6" deep in QC7 alum.
Old 10-29-2003, 06:04 AM
mrainey is on a distinguished road
For chip evacuation, would make a lot of difference if you were on a vertical or horizontal.
I've used plunging to advantage a number of times in place of extra long end mills, but seldom with blind pockets. There aren't too many good ways to mill pockets 6" deep like some of yours, so it would be worth a try. Drill a start hole, then work out the largest stepover value that works for your cutter and leaves a tolerable scallop height for your finish tool to handle.
Don't be surprised if the cycle times are long. It can take a lot of plunges to eat out a large pocket. The benefits are very application-dependent.
4th Axis Parallel Roughing whiteriver Visual Mill 2 06-17-2007 12:10 AM
Smooth outline and pockets pauls BobCad-Cam 0 01-16-2005 08:02 PM
plunge router as z-axis dlenox DIY-CNC Router Table Machines 5 02-11-2004 01:53 AM
Just a question about plunge milling. Machine1 Hard and High Speed Machining 4 01-28-2004 09:36 PM
Roughing end mills for aluminum? Ben General Metal Working Machines 6 06-11-2003 05:04 PM
