Old 10-23-2003, 07:48 PM
brtlatjgt is on a distinguished road
Question npt threads
Can anyone tell me how to program npt threads both internal and external based on the chart in machinery's handbook? In the 26th edition it's on page 1849. Thanks for your help in advance.
Old 10-23-2003, 11:14 PM
CAMmando's Avatar
CAMmando is on a distinguished road
Are you turning or milling ?
Wee aim to please ... You aim to ... PLEASE.
Old 10-23-2003, 11:16 PM
turning
I'm turning but knowing how to use it to thread mill would be helpful as well.
Old 10-23-2003, 11:42 PM
HuFlungDung's Avatar
Moderator
I'm not near my Machinery's handbook at the moment, but for turning, there could be several options, depending on what your controller may have for preconfigured threading macros.
Or, do you want to code each and every movement?
Do you always use a thread insert that exactly conforms to the pitch of the thread you are going to cut, or do you make "one insert do all"? This matters because the amount of truncation of the toolnose at the bottom of the thread, is going to affect the depth you need to go to.
I usually use a threading chart found in the back of the Kennametal turning catalogue, because it shows the infeed amounts at various angles of tool approach, etc. I get an approximate amount from the chart, and program cuts to that depth. I would do a test cut to tweak the final depth setting with the tool offset.
Some threading macros will calculate a "constant horsepower" cut, which automatically decreases the depth per pass as the tool gets in deeper. Is this something that you are wondering about?
BALLSCREW nut threads? Trapper14 Linear and Rotary Motion 6 04-13-2005 01:49 PM
strange bearing preload threads on ball screw mxpro32 Mechanical Calculations/Engineering Design 1 03-10-2005 09:07 PM
Clifton Motor Threads dowling177 Servo Motors and Drives 0 02-07-2005 07:19 PM
turns per inch vs threads per inch pminmo DIY-CNC Router Table Machines 12 08-18-2004 10:27 AM
npt threads scubasteve G-Code Programing 13 03-16-2004 05:37 PM
