Old 04-08-2006, 06:20 PM
JPMach's Avatar
JPMach is on a distinguished road
Question Tool grinder
I was sharpening some endmills the other day and I noticed a lot of vibration in the spindle of my KO Lee tool and cutter grinder. Is there a way to just put new bearings in these or something or do I have to replace the spindle all together, if so where do I find a good replacement?
JP
Old 04-08-2006, 06:25 PM
*Registered*
lakeside is on a distinguished road
check arbor nut not wheel nut make sure everything is tight and try another wheel don't just asume it bearing you could put an indicator on spindle and pull on it by hand there should be no movement
Old 04-08-2006, 06:45 PM
JPMach's Avatar
I just pulled the arbor off and cleaned everything, put the indicator on the taper and get a good .001 movement with just hand pressure.
Old 04-08-2006, 06:48 PM
*Registered*
That Not Much Could Be Defection Try Putting Wheel Back On You May Have Had A Balance Issue Also Check Other End With Pully
Old 04-08-2006, 06:50 PM
*Registered*
Try Dress Wheel If You Were Just Using Stone Or Nawbide Stick Before
Old 04-08-2006, 07:00 PM
Mcgyver is on a distinguished road
are you getting vibration without a wheel? if not, have you balanced the wheel? If the spindle bearings on a grinder are shot, wow, start saving the pennies...I hope its just an improperly balanced wheel
Old 04-08-2006, 07:08 PM
*Registered*
on a ko lee your balance isue is cause more by a ruff dress on the face of wheel or your speed pully should be brought down one range for 6"-8" wheels
Old 04-08-2006, 10:23 PM
yeah but dressing doesn't necessarily fix a wheel balance problem - you could dress till she's the prettiest bell at the ball and still have an out of balance wheel needing balancing - I'm picturing a cup wheel - is that what you're using?
Old 04-09-2006, 07:11 AM
*Registered*
only time I have ever balance a wheel was 12" or over. Did form tool grind at US Repeating Arm and tool and cutter for over 10 years But now that trade has gone to cnc
Old 04-09-2006, 09:52 AM
JPMach's Avatar
Well I cleaned everything real good and put a different arbor adapter on that I had, mounted the wheel (4" cup type), and dressed it. I sharpened a drill in the drill sharpener on it and the finish seems to be a bit better. I will have to get the airflo set back up on it some time in a couple weeks and see how endmills come out.
Old 04-09-2006, 09:58 AM
*Registered*
With cup wheels you should always dish the face of wheel so you are cutting on edge only(10DEG out side to inside) this type of wheel is very aggressive What grit are your using 60-80?
  #12   Ban this user!
Old 04-09-2006, 10:05 AM
JPMach's Avatar
Instead of dishing I just turn the spindle a hair so that it is not parrallel to endmill any more, maybe like 5 deg or so. The wheel is a 80 grit J hard.
JP
