  #13   Ban this user!
Old 03-16-2006, 09:32 AM
CNCfun&games is on a distinguished road
How about using a geneva mechanism that advances 30 degrees per actuation, this will insure that the loading position is always centered precisely.The drive shaft is configured with a photo sensor which triggers a gear motor for "once around " operation. We built one with 10 degrees per actuation,
the geneva wheel was the most complex item to build - using Mastercam to generate the G code helped!
W. Smith
ID:	15672   Click image for larger version
ID:	15673   Click image for larger version
  #14   Ban this user!
Old 03-16-2006, 12:51 PM
buscht's Avatar
buscht is on a distinguished road
Here's a picture of a Thermwood typewriter style toolchanger.
  #15   Ban this user!
Old 08-02-2006, 11:17 PM
snooper is on a distinguished road
Just as a side note: In my line of work, ATC = Air Traffic Controller...
They are usually creatures thoroughly convinced of their exalted position above the rest of mankind; imagine their reactions when I tell them I saw a "home-made" one!
snooper's second law: common sense isn't as common as we're led to believe...
  #16   Ban this user!
Old 12-18-2006, 02:50 PM
h3ndrix is on a distinguished road
Dont know how your project is going, but I hope its well. It looks alot like the one I was working on back in the day. I had to leave it for a few reason, one of which was the rpm limitations on the 30 taper. You can check it out on this link:
http://www.cnczone.com/forums/showthread.php?t=16975
There are nice discussions and some images.
GL
  #17   Ban this user!
Old 12-24-2007, 05:08 PM
benergy is on a distinguished road
I have all the atc carousel parts from a iso25 ceille router, exactly as you described/. their design is exeptional check it out Cielle.it.com i think
  #18   Ban this user!
Old 12-26-2007, 09:47 AM
DrStein99's Avatar
DrStein99 is on a distinguished road
Is that Cielle.it.com a link? www.Cielle.it.com ? Doesnt work.
WWW.RAIDGEAR.NET - FFC cables, foam headset replacement parts, and other gadgets.
Old 12-26-2007, 01:12 PM
ger21's Avatar
Try http://www.cielle.it/
  #20   Ban this user!
Old 12-26-2007, 02:58 PM
ironDigit is on a distinguished road
With all the tooling being tapered i guess the positioning accuracy shouldn't be that tight.Damaging the tapers hould be easily overcome by some strategically placed "rubber"shields.
THX for the good reading.
Finally CHIPS you can have as much as you can without the doc. complainting about your cholesterol.
  #21   Ban this user!
Old 05-04-2008, 12:59 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
I happened on this post a bit late, but I'm surprised nobody has built an ATC similar to the Haas design. I suspect the issue is availability of a suitable taper. If you've got a machine with a classic "CNC" taper, it already has a changer.
But consider that even R8's would work. Forget the repeatability aspect and use a tool touchsetter for tool heights and either R8 collet chucks or end mill holders. Ideally you might want to machine these holds with a slot for spring loaded clamps like those shown on Ken Shea's Haas, but even that might not be necessary with a "drop in" design. There, the tool would sit in a well with a through hole large enough for the cutter (and made of something harmless to cutters like plastic) and tapered to keep the holder upright. Using an R8 also eliminates the need to worry about indexing the spindle to line up with the taper dogs.
The v-groove rail that carries the changer is vintage work for the folks on this board--just like a router's Z-axis. Super precision is probably not needed if there is enough give in the clamping sytem--just get the narrow part of the R8 shank into the bore and let it self-align with the taper on the end. That means even an air cylinder might be adequate to bring the changer in and out of position on its rail, another simplification.
That just leaves indexing the proper tools into position. Here I would simply use a stepper and Gecko or other drive. Direct drive ought to be fine, or you could use a belt, whatever is simpler and can manage the weight of a loaded changer.
Mount the whole thing to the mill column and you'd be in business.
Cheers,
BW
  #22   Ban this user!
Old 11-09-2009, 04:12 PM
Nateg281 is on a distinguished road
Originally Posted by pstockley View Post
I like the rack of tools or carousel mounted on the table as it is simple. However, it is really only suited to bridge type mills. I have seen one on a conventional style mill but I don't like the idea of the long traverse required to pick up the tools. Also I am not too keen on all the tools zipping backwards and forwards. Plus you need some shielding with an automated door to stop coolant and chips getting on the tool holder tapers.
Karl, yes I have seen this and it is very ingenious but I feel overly complicated by the virtue of being totally mechanically actuated. The builder on his forum stated that it couldn't really be scaled up due to the weight of the tool holders. He also estimated it cost around $10,000 to develop because of the injection moulded parts!
Deleted.....found his name
