Old 10-05-2003, 04:15 PM
camfambmw5 is on a distinguished road
Z axis for porter Cable router
Hi all,
I am looking for a way to fabricate a way to support a porter cable router so that is extremely rigid. At this time, I don't need a z axis, just a way to support it (clamp/bracket, etc...). But, down the road (month or 2) I would like to be able to adapt this setup for a z axis
Is there an off-the-shelf part for this? Does anyone have a quick and dirty "how to" on this from a previous post???
Thanks for the effort on this :-)
Old 10-05-2003, 05:05 PM
balsaman's Avatar
balsaman is on a distinguished road
Can you machine aluminum? If no, you could fabricate a clamp or two of sorts from 3/4" MDF. Make a Square, cut it in half, cut out the two half moons, drill thru both halves for bolts and bolt it to the surface for the z axis.
Eric
I wish it wouldn't crash.
Old 10-06-2003, 06:00 AM
E-Stop is on a distinguished road
Like Balsaman said only I would bore my hole in the center of the block and drill the holes thru for mounting before splitting the block in half. This will assure better alignment.
Old 10-06-2003, 07:20 AM
Thanks for the response guys...does anyone out there have some pics they could post of various "home made" z-axis setups that are extremely sturdy and do not require a machine shop to build.
Thanks to all who have and do continue to help me out here
Old 10-06-2003, 08:15 AM
kong is on a distinguished road
There's a nice wooden one over here
Old 10-06-2003, 09:55 AM
HuFlungDung's Avatar
Moderator
One other option might be to rebuild the lower motor housing (endbell) out of aluminum, with extra material on one side of it which will permit you to make a bolt on mount. This would be the hard way to do it, but if you want to ensure some kind of permanent perpendicularity, this would be a way to do it.
3 axis CNC Router with AC/DC Brushless motors (Need help with electronic Design) StressedMech General Electronics Discussion 8 05-15-2005 11:26 AM
Porter Cable Router Motor Mount dowling177 DIY-CNC Router Table Machines 1 04-04-2005 07:40 PM
Round 2 :Z axis for porter Cable router camfambmw5 General Metal Working Machines 2 10-06-2003 12:14 PM
Mounting a porter cable router camfambmw5 DIY-CNC Router Table Machines 5 09-28-2003 08:38 AM
5 Axis Rotery Head Home Cnc Router mace DIY-CNC Router Table Machines 22 09-18-2003 11:29 AM
