Old 09-30-2003, 12:39 PM
camfambmw5 is on a distinguished road
milling aluminum with router(gentry) cnc setup
Have any of you had success with shaping aluminum with a gentry style table and a porter cable like router?
Are there any issues associated with the relatively high speed of the router and working with aluminum?? Is it a stright forward application for a router?
Any feedback would be greatly appreciated.
Thanks ahead of time.
John
Old 09-30-2003, 03:58 PM
balsaman's Avatar
balsaman is on a distinguished road
It works ok. Keep the router speed way up and the feed rate down a bit (depending how rigid your machine is). The smaller the tool, the tougher it is, I have found.
Eric
I wish it wouldn't crash.
Old 09-30-2003, 05:08 PM
Mortek is on a distinguished road
You need some kind of coolant on the cutter either spray mist or flood. Misters are available though MSC, Mcmaster Carr, Enco, or your local industrial supply shop. If you don't cool the cutter it will load up especially under high rpms.
Old 12-04-2003, 02:03 AM
whiteriver's Avatar
whiteriver is on a distinguished road
What would you say a good rate of travel for a 1/4" carbide endmill in 6061 would be with a 3 1/2 hp porter cable router. Gantry is rock solid. Was designed for 4 12hp routers. What would be a good plunge feed rate? How about recomended depth per pass..
Ok same question for 1/8" and 1/2" end mills also.
Donny
Old 12-04-2003, 02:32 AM
What RPM ? Is your rpm variable?
Old 12-04-2003, 11:31 AM
whiteriver's Avatar
Not quite Sure. I picked up a rpm controll for $15 from Harbor Freight. It slows it down pretty good. But not to a definat speed. No way to dial it in.
Donny
Heads Up - Article about building CNC Milling Machine samualt CNCzone Club House 3 06-13-2005 03:43 PM
CNC Aluminum studysession General Metal Working Machines 6 02-12-2005 10:39 AM
Machinist - CNC Setup & Operator in FLA sundara Employment Opportunity 0 12-24-2004 10:35 AM
Taig CNC ready setup help?? efreak Taig Mills & Lathes 2 08-24-2004 08:30 PM
