Old 02-05-2006, 03:02 PM
Hellbringer is on a distinguished road
What Machine To Use
i need to make this:
which has the offset so i dont think can use a lathe because that would take a even amount off all sides and it needs to be more precise than a grinder thanks Mike
Old 02-05-2006, 04:38 PM
Mcgyver is on a distinguished road
4 jaw chuck in the lathe, dial in the offset with an indicator is how'd i'd do. eccentric turning in the lathe is quite common, sometimes even on purpose
Old 02-05-2006, 05:15 PM
I you are doing a large number of them make a split sleeve to grip them. Dial the offset on the sleeve in the four jaw, bore a hole 2 or 3 thou larger than the O.D. of the work piece and cut a slit in the sleeve. Now you can grip them correctly off center in a three jaw and do not have to dial every one. In this context even five could qualify as a large number.
Old 02-05-2006, 05:30 PM
you can do that off center a peice of work in a lathe.... wont it be unbalenced???? Thanks Mike
Old 02-05-2006, 06:28 PM
yup. when something is out of balance, you slow the machine down until it doesn't matter. in extreme cases, like a big casting fixed to a faceplate, you use counter weights. for those pieces just don't run full speed - you'll know soon enough if you are running an eccentric job too fast
Old 02-05-2006, 07:23 PM
lol ok thanks guys
