Old 02-01-2006, 09:30 PM
pimp215 is on a distinguished road
Question speeds and feeds for slitting with hss
Why is it imposible for me or anyone I know to find any speeds and feeds
for milling a slot with a hhs slitting saw? Dose any one have a surface footage
for 1018 or a table for this type of cutting?
Old 02-01-2006, 10:01 PM
spm=suface feet per minute;rpm=revoultions per minute
spmx4 then divide that # by your cutter radious =your rpms
I need to know what spm is on 1018 mild steel with a 3 inch diamiter .018 thousanths thick slitting saw.
Old 02-01-2006, 10:17 PM
Mcgyver is on a distinguished road
the texts will say 80-100 fpm for hss cutting mild steel, keep in the mind those figures are always under ideal conditions and should be considered a maximum. that number is the max surface speed for hss/mild steel, doesn't matter the cutter...ie same formula for figuring out the max speed for a drill for hss/mild steel.
Old 02-03-2006, 12:39 AM
so a want the same rpms for a 1 inch dia. drill as a 1 inch dia. slitting saw?
Old 02-03-2006, 06:55 AM
yes and no. surface speed is jus that, the max speed between cutter and work in say feet/min, and changes with material and cutter. spindle speed is determined by the surface speed + all other factors (setup etc) in theory if its hss into mild steel the surface speed is the same but there's other factors, how heavy is the cut, how rigid is the setup/machine etc. I'd run a slitting saw slower, but for set up reasons not because the max surface speed has changed consider getting a copy of machinery's handbook, and/or google maching feeds and speeds, or some machining texts its no problem answering some questions but you'd benefit from a deeper understanding as this stuff is core to metal working
here's a start
http://www.bitlady.com/speedfeed.php
here's another that i like cause I knew Robert
http://yarchive.net/metal/empirical_feed_rates.html
Robert Bastow "t-nut" was one of the most knowledgable and helpfull metal workers on the net imo, he's no longer with us but googling sometime churns up some of his delightfull tidbits
Old 02-23-2007, 02:55 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
here's a start
Tidbits????? Thanks for sharing that link. Robert Bastow had a true love for the Trade. I enjoyed that and will share it with others.
Cheers!!!!!!
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 02-23-2007, 05:22 PM
jackson's Avatar
jackson is on a distinguished road
here's a start
Robert Bastow "My hero" !!!!! That was the greatest thing i have read in awile i have a new bed time story LOL
individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
