Old 01-22-2006, 11:08 AM
OckamsRazor is on a distinguished road
$760 Northern tool selling Vertical mill + Lathe combo
Does anyone recognize this mill?
Any thoughts if it would be a good starter for small stuff?
Would it adapt to CNC with steppers?
http://www.northerntool.com/webapp/w...Id=7171&R=7171
Old 01-23-2006, 09:52 AM
wizard is on a distinguished road
That looks fer similar to the one that HF sells.
Generally it is thouoght that combination machines are a bad idea. That may be true in the general case but you would have to decide if your specfic case merits use of the machine. The primary issue is that one machine function might be in use while that other is needed also.
As to the machine itself to be honest I looked at the HF variant for some time tring to determine what it would be good for. It could be argured that this machine might make a good CNC lathe platform due to a nice swing and the lack of conventional lath parts to move around or waste.
Dave
Old 03-19-2006, 06:53 PM
sanddrag is on a distinguished road
That looks identical to the one Harbor Freight sells. I've seen it in person. I wouldn't do it. Low quality and won't do milling or turning as well as separate machines. At they HF I went to, it was on clearance for about $420 and I still didn't want it.
Old 03-19-2006, 06:59 PM
*Registered*
lakeside is on a distinguished road
you get what you pay for
Old 03-19-2006, 07:10 PM
ZipSnipe is on a distinguished road
Cummins = Minimill $399, Homier= Mini(7x10) lathe $299
