Old 09-11-2003, 11:02 AM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
How do you Identify
what type of stainless steel? I have a piece of SS and don't know what type it is how can I find out?
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 09-11-2003, 11:11 AM
HuFlungDung's Avatar
Moderator
You can test it with a magnet. If the magnet doesn't stick then its.....non-magnetic This would likely mean a 304 to 316 grade. You can heat up a piece (red hot) and quench it, and it will not test any harder than it was before.
If you cut a sample in a lathe, and it forms short chips, it is likely a sulferized grade, like a 416 MX. This grade will also harden to some degree (40 Rockwell), which may not seem all that hard (nowhere near "file hard") but they call it hardenable.
The other types that are used for hardened blades and stuff, I don't know about. They would be much harder, I guess, if you heat up a piece and water quench it to find out.
Old 09-11-2003, 03:41 PM
Mortek is on a distinguished road
find someone with an electron microscope and it will print out what elements are in it and how much of each one. then compare it to a stainless alloys chart. Metalugical lab a good place to start.
Can anyone identify this program? Velox_Skates General CAM Discussion 2 01-28-2005 01:46 AM
Help to identify another piece o junk again. Konstantin General Electronics Discussion 13 09-25-2004 01:12 PM
Help to identify this stepper. Konstantin General Electronics Discussion 12 04-12-2004 06:54 AM
Trying to identify steppers Konstantin General Electronics Discussion 5 03-08-2004 03:37 AM
How to identify a Servo motor Mr.Chips General Electronics Discussion 7 10-23-2003 12:42 AM
