Old 01-14-2006, 03:58 PM
Rufan is on a distinguished road
Brother TC-215 CRT problems
On my brother tapping center the CRT screen is broken. So now I put an external TV on it and it works fine. But is want to put a screen back into the machine. I bought a TFT monitor and installed into the machine. But than the problem begins. The TFT display is working but the image is not steady. I think it has some problems with the frequentie.
Do some body know if i can make a convertor or a way to make the image steady. It's like it missing some frames per second.
Old 01-14-2006, 04:16 PM
Al_The_Man's Avatar
Was the monitor you replaced it with a analogue VGA or TTL? if so what resolution?
I assume you have fitted a TFT monitor with built in display controller , does it have 15pin vga or 9 pin connector?
Some of the older CRT displays were low freq EGA.
Old 03-29-2006, 02:23 AM
Ben Colby is on a distinguished road
Do you upload and download programs from your Brother CNC to a computer?
If so, what cabling and software are you using?
Ben
