Old 12-26-2005, 01:41 PM
guido's Avatar
guido is on a distinguished road
Milling spindle
I would like to have some comments, experience or advise you all have for a milling spindle.
For instance:
Type of toolholder.
Automatic on manual change.
Power (hp or kW).
RPM range.
Type of motor and drive.
Refer to spindles you're currently using...what is good and bad about them.
At the moment I'm considering a design with a ER collet toolholder for a tool size of max 10mm and a direct drive spindle motor. Capable of 30k-40k (more?) rpm.
Guido
Old 12-27-2005, 11:06 AM
wizard is on a distinguished road
The only things I'm familiar with at the moment are R8 and collets on routers. That and the use of air bearing spindles and special collets. Not much to be honest.
As to collets for a new spindle 9which I'm assuming is home made) ER would be ideal as long as tool changes are not common. I say this because the actual cutting of the tapers should be realtively easy for just about any shop.
As to speed and horse power that is totally up to your needs as dictated by the applications. Just getting reasonable torque at 30K Will imply a bit of horse power.
The biggest problem with spindles is the high RPM's you are asking about. do not expect your bearings to last a very long time, Do become familiar with Kytox and a good local bearing distributor.
dave
Old 12-28-2005, 09:24 AM
Mcgyver is on a distinguished road
with a max size of 10mm, consider replicating a Foredom collet spindle. the collets are inexpensive. I've the collet and spindle drawings somewhere but will have to look for them - if you are interested.
edit: i checked their site, http://www.blackstoneind.com/foundations/store/home.asp
and the largest is .250", so not big enough for you
Old 12-28-2005, 10:04 AM
Steve F is on a distinguished road
Thumbs up
I'm building my bench top mill useing the ER collets as you mention also,max size being 10mm and I have a direct drive Dumore .5 hp with 16K no load and 8K loaded motor.It's still miles away from being done,but one thing at a time
Old 12-28-2005, 10:43 AM
RotarySMP's Avatar
RotarySMP is on a distinguished road
I have the sherline industrial ER16 collet spidle, which maxes out at 10mm. This is pretty small if you want to mount a boring.
Regards,
Mark
www.wrathall.com
