Old 12-19-2005, 07:48 PM
phantomcow2 is on a distinguished road
Is there a formula for depth of cut?
Milling down some steel today on a bridgeport, and i would like to know if theres a formula for depth of cut.
I looked in some of the books and there was no reference to it...
Using a 1" 4 flute end mill
Old 12-19-2005, 08:16 PM
Gold Member
Ken_Shea is on a distinguished road
There are just so many variables that it seems highly unlikely that there would be any meaningful formula that is documented and held by professional machinist as reliable. (could be wrong of course)
Check this out, it is free with no time limit, fully functional and incredibly useful.
http://www.mrainey.freeservers.com/
It will permit you to view the results of a nearly unlimited number of all those variables and what ifs.
The Pro version is available for purchase and provides many additional features.
Take time to read the docs and explore all the very useful functions that Michael Rainey has given to who ever want to give it a try.
This probably goes without saying but a 1" cutter can take quite a cut, consequently the part needs to be extremely secure while doing it. A 1/8" grip in a imported vise ain't going to get it
Old 12-21-2005, 08:40 AM
AMCjeepCJ's Avatar
AMCjeepCJ is on a distinguished road
Not sure if this will help at all or not but if you'd like to climb cut and bury the cutter on a manual mill, lock the gibbs down pretty snug and put a 3/4" box wrench on the nut at the handle... This will give you incredible leverage to override the gibbs being snug and you can climb cut, not to mention get a sick finish compared to conventional milling. The point being your cutter can't jerk the work into your cutter and snap it... I like to think of it as 'poor mans ballscrews'... I've done it on a manual lathe too and it knocked down chatter considerably when coupled with a small stick rubbing on the part~
I agree with Ken though, waaaay to many variables, I go by feel normally, or if I get a good cut on my cnc's write down what works for a ball park reference next time and adjust in 10% increments...
ps
lock your gibbs in both X & Y or you'll regret it, chances are you'll break some cutters learning this method, so don't try it on something important...
Gimpy aka 313 (three thirteen)
The early bird may get the worm, but the second mouse gets the cheese.
Old 12-21-2005, 11:30 AM
Mcgyver is on a distinguished road
like Ken says many variables on what force the cutter experiences, biggies being material, feed rate, rigidity of machine, rigidity of set up etc.
A rule of thumb I've been told for end mills is max depth is about 1/2 the cutter dia, but it's only a rule of thumb
