Old 08-27-2003, 03:38 AM
Capteod is on a distinguished road
Data on Zero Backlash Nuts?
I am converting a Rong Fu mill to CNC and the use of a single ball screw nut unloaded is not my idea of accuracy. Does anyone have a good idea on how to make a antibacklash nut using two unloaded nuts.
I have looked at numerous websites and I have not found any good ideas.
Thanks in advance as this group has numerous good thinkers and this idea is bugging me. I am used to programming machines with glass scales and accuracies in the 0.1 mircon area for HIGH RELIABILITY AEROSPACE applications and I want a highly accurate machine for home shop use.
Old 08-27-2003, 10:26 AM
NeoMoses's Avatar
NeoMoses is on a distinguished road
Although I don't currently have any good plans for building your own preloaded nuts, I am going to recommend Moglice. It's a great product, inexpensive, and gave me less than 0.002" backlash the first time I tried it. In theory, you can get less than 0.0005" backlash with it, but it might take a couple of tries.
My name is Electric Nachos. Sorry to impose, but I am the ocean.
http://www.bryanpryor.com
Old 08-27-2003, 10:28 AM
kong is on a distinguished road
HomeCNC has some plans for sale on his website I'm sure he'll be along later to fill you in.
Old 08-27-2003, 11:04 AM
HomeCNC's Avatar
HomeCNC is on a distinguished road
I have taken two ball nuts and made the ability to pre-load two wave washers against the nuts to get pressure seperating them on the screw. This is how the purchased ones work. I did this because of the price of the pre-loaded ball nuts are aroung $160 each from Reed Tool or McMaster Carr. You can get single nuts for $23 each and build the parts between to make the same thing.
Remember that the nuts are only ONE part of removing backlash. You can get backlash built-up from linear movement of the screw as well.
Jeff Davis (HomeCNC)
http://www.homecnc.info
Ballscrew Basics Swede Linear and Rotary Motion 94 09-06-2011 07:23 PM
Anti - Backlash Nuts Mhiran DIY-CNC Router Table Machines 62 02-18-2010 08:55 AM
CNC Glossary CNCadmin CNCzone Club House 17 03-09-2008 04:08 PM
Backlash with worm drives ? andy_ck87028 Mechanical Calculations/Engineering Design 9 02-02-2005 05:40 AM
Extensive Tool data for OnecncXP HuFlungDung OneCNC 7 05-23-2003 02:34 PM
