Results 1 to 6 of 6
Thread: Heidenhain Programming Help !
    Jan 2012
    Romania
    Exclamation Heidenhain Programming Help !
    I am working on a Horizontal CNC Boring Mill (5 axis) machine with an iTNC530 Heidenhain Panel and i have a preety hard program to do and i don't know how to make it.
    I attached a photo so you can see what i am talking about ... i have to make a half circle on Z Y axis and i dont know how to do that ... i tried with the C an CC function but no luck ... I am tring to do this with a 40 mm diameter mill
    Please help me guys
    Attached Thumbnails Attached Thumbnails Heidenhain Programming Help !-untitled-1.jpg
    Registered christinandavid's Avatar
    Aug 2009
    New Zealand
    Don't know about any more advanced 5-axis options, but on a 3-axis the first thing I would do is a Tool Call with X as the spindle axis.
    Would probably set up a spherical cutter using the centre of the sphere as the reference point for my tool length/radius and program it using CC and C movements as you thought (arc radius size = part radius + cutter radius), incrementing in X.
    DP
    Jan 2012
    Romania
    Thank you for the quick reply but i was wondering if you can please give an example of an ark for my case situation.
    Dec 2011
    Hungary
    ShiZniT,
    The figure is not right hand rule coordinate system represented by!?
    0 BEGIN PGM ShiZniT MM
    1 Q0 = 20 ;Radius 20
    2 Q1 = 12 ;Length 50
    3 Q8 = 1 ;Step 1
    4 BLK FORM 0.1 Z X+0 Y+0 Z+0
    5 BLK FORM 0.2 X+Q1 Y+Q0 Z+Q0
    6 TOOL CALL 8 Z S3000 F500
    7 FN 18: SYSREAD Q2 = ID20 NR1
    8 FN 18: SYSREAD Q2 = ID50 NR3 IDXQ2
    9 Q3 = Q2 + Q0
    10 Q4 = Q108 - Q2
    11 Q9 = Q0 + 2
    12 L Z+Q9 R0 FMAX M3
    13 CC Y+Q4 Z-Q2
    14 L X+0 Y+Q4 FMAX
    15 Q7 = INT ( Q1 / Q8 ) - 1
    16 LBL 1
    17 L Z+Q0 F AUTO
    18 C IY+Q3 Z-Q2 DR-
    19 L Z+Q9 FMAX
    20 L IX+1 Y+Q4 FMAX
    21 CALL LBL 1 REPQ7
    22 END PGM ShiZniT MM
    Jan 2012
    Romania
    Thank you
    Thank you very much for your help .. i appreciate this ..
    Jan 2012
    Romania
    and sorry for my mistakes in the drawing ..
    1. Newbie- Heidenhain TNC145 Programming
      By mally in forum Bridgeport and Hardinge Mills
      Last Post: 12-24-2010, 08:18 PM
    2. Need Help!- Heidenhain programming
      By chintan in forum Fadal
      Last Post: 10-19-2010, 07:34 AM
    3. Heidenhain CNC programming
      By mrbob2 in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 07-02-2010, 02:48 AM
    4. Heidenhain programming ?
      By bherr in forum Bridgeport and Hardinge Mills
      Last Post: 02-28-2007, 11:17 AM
    5. Heidenhain programming problems
      By lt1pat in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 03-12-2006, 11:28 AM
