Servos really aren't necessary in a machine the size that you're talking about. Most small machines use stepper motors and work just fine. Steppers also have the advantage of being easy to setup (no servo loop to tune) and low maintenance (they're sealed and brushless).
I would recommend a 3 or 4 axis stepper kit from CNCRouterParts.com, significantly less expensive and the steppers will bolt directly onto the Sherline.
LinkBack URL
About LinkBacks
