Thank you all for your extremely well thought out ideas, let me explain my situation a little bit further.
I do have a large area currently, big enough that I could easily fit a TM1 or VF1 with no problems, alas, I do not have enough cash for one of those beautiful machines.
For my uses, I will be mostly making small bicycle components, derailleur parts, stems, linkage bits. etc.
I have one more year (my third) at my technical school where I will be getting a second diploma to add to my Manufacturing one. Here this gives me year round access to our
CNC mills and Lathes.
My idea being that I can have a small machine like the Sherline and modify it to my uses. I am thinking the 2000 model, then buying some 80/20 aluminum extrusion, tapping it, and removing the x-y axis swivel, and just retaining the tilting Z axis. This will stiffen the entire machine. Most of my work (95%+) will be with milling 6061-T6 aluminum, at small depths. If I was to need to cut steel I could always revert the pulley on the machine back to it's 2800RPM max one.
The nice thing is, I'm planning on moving out to a small home, and having a little desktop machine like a tiag or a sherline would be beautiful for fitting in a garage shop or the like.
