Results 1 to 6 of 6
Thread: Air dryer options
    Feb 2012
    Air dryer options
    Trying to figure out how much air drying power I need. I have a small Roland MDX-540 with the automatic tool changer which needs a compressed air supply. The little $10 inline silica gel option does not last long. All the refrigerated air dryer options start around $500 and seem like overkill. When I look at the specs all the units start using at about 5AMPs of 120v power. It doesn't seem like my unit uses that much air. Is this my best option or is there something else out there I should be looking at?
    Feb 2009
    You can get a small dryer at harbor freight. Last time I looked and today even I have a 25% off coupon. Makes it less than 300. Or, you can run vertical lines up the wall and back down that are twice the size of your horizontal lines. Place a water separator before and after the vertical lines. Gives the air a chance to slow down and cool in the lines, makes separation much better.
    Feb 2012
    Tried to get the harbor freight one with the coupon this morning. They were out and said it was discontinued. Web site says out of stock.
    I might try the vertical line thing. Although right now the compressor is in the attic and makes an 8 foot drop into the garage. At the bottom of the drop is a water trap. Then the line goes to my mill at the end of a 25ft hose. The hose travels up about 6 feet before going into another water trap that is attached to the mill. I never have any water in the water trap on the mill. Do you think my setup is OK then? I have a silica gel filter in that 25ft run that starts off blue and then turns pink when it is wet. It turned pink after a couple days so I figured I needed a longer term solution.
    May 2004
    United Kingdom
    Silica gel can be recyled in your oven while the wife is out! Just warm it up for a while to dry. If you had two cartridges you could cycle them whilst the dinner is roasting <G>
    Andrew Mawson
    East Sussex, UK
    Feb 2009
    Get the hose out of the set up. Hose holds heat more than copper, by a lot, and that can lead to more water. Use short hose from the wall to the machine only. The desiccant filters like that type are prone to early replacement. I only use them for painting. There are other large desiccant filters that work well, they are full of pellets and stand 2 ft high. If your not seeing any water by the machine, this all may be overkill. We only use extra desiccant for the air bearing spindles. Those need it.
    Jan 2010
    I have one of these on a plasma cutter and it works great. Takes out water, oil, and particles. M26 and M60
    1. Air Dryer
      By TonyWish in forum Plasma, EDM and other similar machine Project Log
      Last Post: 07-18-2011, 04:40 PM
    2. Refrigerated air dryer question
      By tinman13 in forum General Waterjet
      Last Post: 12-11-2010, 08:54 AM
    3. air dryer
      By grogsroom in forum General Waterjet
      Last Post: 12-12-2009, 08:57 AM
    4. Newbie- Need an Air Dryer Solution
      By Dartok in forum General Waterjet
      Last Post: 08-25-2008, 07:12 AM
    5. Figuring out VMC air CFM needs for an air dryer?
      By SRT Mike in forum General Metal Working Machines
      Last Post: 06-22-2006, 12:17 AM
