Results 1 to 4 of 4
Thread: How to tell system to offset movement in X/Y for a part that's not square (GCODE)
    Dec 2009
    Hard to describe what I want in that subject line. I'm going to be doing a bit of PCB drilling and the biggest pain in the butt for doing it is having to square a hole pattern that is not yet there to the axis movement for X/Y when the sides of the board can't be used as a reference.
    What I want to be able to do, and I think is possible is to visit two points that are designed as being a straight line and then from those let the machine figure out the slight angle that the board may be sitting at. Otherwise I have to jump back and forth between the points trying to tap the board into squareness and it's an iterative process that takes forever. I only like setting up on the mill for this just slightly better than drilling them by hand.
    I know there is a way to do that but I'm not sure what it's called so I have not had much luck looking for it.
    CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
    May 2004
    Most controls allow for coordinate system rotation. G68 is a common G-code to execute this. G69 cancels the G68. To find the amount of rotation, you could edge find two points along the Y axis with a known distance between in Y and obtain the X locations for those two points. Once you have the slope of the line, the angle can be known. You would also want two points along the X axis to find the intersection to have a known corner location and point of rotation. That corner becomes your part zero and point of rotation and reference position of the other features.
    http://www.kirkcon.com/
    Dec 2009
    Ahhhh, rotation. I was not looking for that but makes perfect sense. Thanks! The difficulty will be in defining the origin of rotation. with the system I have it will be off the board. I guess I could use the hole in the clamp to get pretty close as that is the real pivot point. I'll need to make sure I over-size part of the hole so tapping it doesn't ruin it as a reference.
    Thanks again for the info.
    Oct 2008
    what kind of machine is it?
    what control?
    do you have a probe?
    are all the parts a little different from each other?
    how many parts are you doing?
    If your control has macro capability and you have a probe, this isn't exactly trivial but it's not real hard.
    Quick way to check if you controller can process macros:
    Type
    #1=1;
    in MDI or at the top of a program, and if it doesn't alarm when you run it, you're good to go. Oh, nothing will happen and the machine won't move.
  1. Part offset question
    By l u k e in forum Haas Mills
    Last Post: 06-03-2011, 12:53 PM
  2. Need Help!- drawing from Gcode in wireEdm using offset
    By rattyratty07 in forum General CAM Discussion
    Last Post: 09-14-2010, 08:28 AM
  3. taper in square part
    By larry53 in forum Autodesk Software (Autocad, Inventor etc)
    Last Post: 10-28-2009, 09:57 PM
  4. Is there a way to feed an offset in manually in Gcode
    By seanreit in forum General Metal Working Machines
    Last Post: 12-13-2008, 10:30 PM
  5. Question about part offset, G54-59
    By Sticky Racing in forum G-Code Programing
    Last Post: 12-05-2007, 10:46 PM
