Results 1 to 5 of 5
Thread: CNC GEAR PONITING HELP
    Jul 2005
    I am tring to find some info on several different brands of cnc gear pointing machines if anyone is familiar with any please let me know what they are.
    Mar 2006
    Gear pointing????????
    I'm familiar with gear hobbing, shaping, shaving, honing, form milling and grinding but not gear pointing.
    Dick Z
    DZASTR
    Mar 2006
    smooooooth, What are you looking for? Please explaining "gear pointing machine". We build gear hobbing machines. That is, machines that cut gear teeth into gear blanks. Is this what you are referring to?
    There are also gear chamfering machine that break the sharp edges on the ends of gear teeth.
    We'd like to help but do not know what information you're asking for.
    Dick Z
    DZASTR
    Jul 2005
    This machine puts a point on the tooth for easier meshing of two gears found out from Gleson that they make these machines.
    Mar 2006
    Those are generally referred to as gear tooth chamfering machines. There are several different brands available.
    Try "googling" gear chamfering machines. Also available on the used machine market. Cross is one brand name. There are others as well.
    Dick Z
    DZASTR
    1. Basic Bevel Gear - Milling a valley for gear teeth
      By ngr1 in forum General CAM Discussion
      Last Post: 04-05-2012, 10:55 AM
    2. What size gear belts for stepper gear reducer?
      By Danno in forum Plasma, EDM and other similar machine Project Log
      Last Post: 09-28-2011, 05:28 PM
    3. Need a Lagun Lathe Gear or Custom Gear Maker
      By douglasco in forum General Metal Working Machines
      Last Post: 01-12-2011, 09:54 AM
    4. NEED "gear" spur gear?? extrusion
      By mryeagle in forum Want To Buy...Need help!
      Last Post: 10-29-2008, 07:16 AM
    5. Spur Gear / Gear Rack
      By ckrantz in forum Linear and Rotary Motion
      Last Post: 12-07-2006, 12:06 AM
